Introdução
This guide will show you how to replace the diaphragm assembly. A faulty diaphragm assembly can lead to a few different issues including irregular shaking, grinding, or leaking grease.
O que você precisa
Remove the two 10mm T-10 Torx screws that attach the top brush holders to the motor housing.
Remove the two 10mm T-10 Torx screws that attach the bottom brush holders to the motor housing.
Remove the metal piston from the diaphragm assembly.
Um comentário
to reasemble .
Which is the correct position of the Shift knob assembly ?
