Ir para o conteúdo principal
Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement
O que você precisa
  1. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement, Housing Assembly: passo 1, imagem 1 %32
    • Remove the ten 19mm T20 Torx screws shown in red.
  2. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: passo 2, imagem 1 %32
    • Remove the red Housing Assembly by lifting it up off of the tool.
  3. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement, Reduction Gear Assembly: passo 3, imagem 1 %32 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement, Reduction Gear Assembly: passo 3, imagem 2 %32
    • Remove the two 10mm T-10 Torx screws that attach the top brush holders to the motor housing.
    • Remove the two 10mm T-10 Torx screws that attach the bottom brush holders to the motor housing.
  4. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: passo 4, imagem 1 %32 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: passo 4, imagem 2 %32
    • Using a metal spudger, pry off each brush holder.
  5. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: passo 5, imagem 1 %32 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: passo 5, imagem 2 %32 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: passo 5, imagem 3 %32
    • Remove the four 37mm T20 Torx screws shown in red.
  6. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: passo 6, imagem 1 %32 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: passo 6, imagem 2 %32
    • Pull the front portion of the tool out from the motor housing.
  7. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: passo 7, imagem 1 %32 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: passo 7, imagem 2 %32 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: passo 7, imagem 3 %32
    • Remove the two 11.5mm T10 Torx screws shown in red.
  8. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: passo 8, imagem 1 %32 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: passo 8, imagem 2 %32
    • Pull the 120V armature assembly out of the diaphragm assembly.
  9. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: passo 9, imagem 1 %32 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: passo 9, imagem 2 %32
    • Using a metal spudger, pry the diaphgram assembly out of the gear case.
  10. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: passo 10, imagem 1 %32 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: passo 10, imagem 2 %32
    • Now that you have loosened the diaphragm, you can now pull it out of the gear case.
  11. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: passo 11, imagem 1 %32 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: passo 11, imagem 2 %32 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: passo 11, imagem 3 %32
    • The diaphragm assembly will be lathered in grease. In order to move forward, you may want to give it a wipe down to remove any extra grease.
    • After removing some grease (if needed), remove the two 15mm T20 Torx screws shown in red.
  12. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: passo 12, imagem 1 %32 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: passo 12, imagem 2 %32 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: passo 12, imagem 3 %32
    • Now pull the reduction gear assembly up and out of the diaphragm.
  13. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement, Diaphragm Assembly with Bushing: passo 13, imagem 1 %32 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement, Diaphragm Assembly with Bushing: passo 13, imagem 2 %32
    • Remove the metal piston from the diaphragm assembly.
  14. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: passo 14, imagem 1 %32 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: passo 14, imagem 2 %32 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: passo 14, imagem 3 %32
    • Using a metal spudger, pry the o-ring off of the assembly.
Conclusão
Payton Parker
Membro desde: 03/08/19
534 Reputação
Autoria de 2 guias
Equipe
Um comentário
to reasemble .
Which is the correct position of the Shift knob assembly ?
Javier Martinez - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 9
Duração total: 1,010
