Ir para o conteúdo principal
Milwaukee 2780-20 Trigger Assembly Replacement
O que você precisa
  1. Milwaukee 2780-20 Trigger Assembly Replacement, Trigger Assembly: passo 1, imagem 1 %32 Milwaukee 2780-20 Trigger Assembly Replacement, Trigger Assembly: passo 1, imagem 2 %32 Milwaukee 2780-20 Trigger Assembly Replacement, Trigger Assembly: passo 1, imagem 3 %32
    • Using a Torx T20 screwdriver, unscrew the four 16mm screws from the case.
    • Switch to the Torx T10 screwdriver, and remove the last 16mm screw from the hilt.
  2. Milwaukee 2780-20 Trigger Assembly Replacement: passo 2, imagem 1 %32 Milwaukee 2780-20 Trigger Assembly Replacement: passo 2, imagem 2 %32 Milwaukee 2780-20 Trigger Assembly Replacement: passo 2, imagem 3 %32
    • Using the Torx T20 screwdriver, unscrew the four 28mm screws located at the bottom (and top) of the gearcase assembly.
    • Remove the two 12mm screws with a Torx T20 screwdriver in order to get to the others.
  3. Milwaukee 2780-20 Trigger Assembly Replacement: passo 3, imagem 1 %32
    • Pull apart the housing handles.
  4. Milwaukee 2780-20 Trigger Assembly Replacement: passo 4, imagem 1 %32 Milwaukee 2780-20 Trigger Assembly Replacement: passo 4, imagem 2 %32 Milwaukee 2780-20 Trigger Assembly Replacement: passo 4, imagem 3 %32
    • Lift the trigger assembly off of its mount.
    • Dispose of the old trigger assembly and install the new one.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 16
Duração total: 1,169
