Ir para o conteúdo principal
Milwaukee 2704-20 Trigger Replacement
O que você precisa
  1. Milwaukee 2704-20 Trigger Replacement, Outer Case: passo 1, imagem 1 %32 Milwaukee 2704-20 Trigger Replacement, Outer Case: passo 1, imagem 2 %32
    • Remove the battery from the drill.
  2. Milwaukee 2704-20 Trigger Replacement: passo 2, imagem 1 %32 Milwaukee 2704-20 Trigger Replacement: passo 2, imagem 2 %32 Milwaukee 2704-20 Trigger Replacement: passo 2, imagem 3 %32
    • Remove the indicated screws (M3 x 16mm Pan Hd. ST T-10 Screws) with screwdriver.
  3. Milwaukee 2704-20 Trigger Replacement: passo 3, imagem 1 %32 Milwaukee 2704-20 Trigger Replacement: passo 3, imagem 2 %32 Milwaukee 2704-20 Trigger Replacement: passo 3, imagem 3 %32
    • Gently lift the cover off the drill. Be careful not to force it or damage any of the internal components.
    • If the cover doesn't come off easily, check for any clips or latches that may be holding it in place. These can usually be released by pressing them with a small flathead screwdriver.
  4. Milwaukee 2704-20 Trigger Replacement, Trigger: passo 4, imagem 1 %32 Milwaukee 2704-20 Trigger Replacement, Trigger: passo 4, imagem 2 %32
    • Desolder the two solder joints on the trigger assembly.
    • USE CAUTION! Soldering irons get extremely hot, as will everything they make prolonged contact with.
  5. Milwaukee 2704-20 Trigger Replacement: passo 5, imagem 1 %32 Milwaukee 2704-20 Trigger Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using tweezers, remove the header connector.
    • To avoid damage, be careful replicating this step in both the removal and replacement processes.
  6. Milwaukee 2704-20 Trigger Replacement: passo 6, imagem 1 %32
    • Remove the trigger mechanism entirely.
Conclusão
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 64
Ao todo: 629
