Ir para o conteúdo principal
Milwaukee 2704-20 Control Switch Replacement
O que você precisa
  1. Milwaukee 2704-20 Control Switch Replacement, Outer Case: passo 1, imagem 1 %32 Milwaukee 2704-20 Control Switch Replacement, Outer Case: passo 1, imagem 2 %32
    • Remove the battery from the drill.
  2. Milwaukee 2704-20 Control Switch Replacement: passo 2, imagem 1 %32 Milwaukee 2704-20 Control Switch Replacement: passo 2, imagem 2 %32 Milwaukee 2704-20 Control Switch Replacement: passo 2, imagem 3 %32
    • Remove the indicated screws (M3 x 16mm Pan Hd. ST T-10 Screws) with screwdriver.
  3. Milwaukee 2704-20 Control Switch Replacement: passo 3, imagem 1 %32 Milwaukee 2704-20 Control Switch Replacement: passo 3, imagem 2 %32 Milwaukee 2704-20 Control Switch Replacement: passo 3, imagem 3 %32
    • Gently lift the cover off the drill. Be careful not to force it or damage any of the internal components.
    • If the cover doesn't come off easily, check for any clips or latches that may be holding it in place. These can usually be released by pressing them with a small flathead screwdriver.
  4. Milwaukee 2704-20 Control Switch Replacement, Control Switch: passo 4, imagem 1 %32 Milwaukee 2704-20 Control Switch Replacement, Control Switch: passo 4, imagem 2 %32 Milwaukee 2704-20 Control Switch Replacement, Control Switch: passo 4, imagem 3 %32
    • Remove the control switch.
    • It is not attached to anything and should slide out easily. Take note of orientation and be sure to replace it in the same position.
Conclusão
Unique Linnell
Membro desde: 03/13/23
423 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 2-1, Petersen Spring 2023 Membro de UMass Dartmouth, Team 2-1, Petersen Spring 2023
UMASSD-PETERSEN-S23S2G1
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 257
