Ir para o conteúdo principal
Midland X-tra Talk Radio LXT118 Antenna Replacement
O que você precisa
  1. Midland X-tra Talk Radio LXT118 Antenna Replacement, Batteries: passo 1, imagem 1 %32 Midland X-tra Talk Radio LXT118 Antenna Replacement, Batteries: passo 1, imagem 2 %32
    • First, apply pressure with your thumb on the top of the battery cover.
    • Next, pull down on the cover until it begins to slide.
  2. Midland X-tra Talk Radio LXT118 Antenna Replacement: passo 2, imagem 1 %32
    • Finally, once the cover is completely off, pry up the old batteries with your finger or a strong, skinny tool (i.e. spudger).
  3. Midland X-tra Talk Radio LXT118 Antenna Replacement, Case: passo 3, imagem 1 %32
    • Unscrew the six 8.0 millimeter long, #0 screws on the backside of the case using the Phillips #0 screwdriver.
  4. Midland X-tra Talk Radio LXT118 Antenna Replacement: passo 4, imagem 1 %32
    • Detach back part of the case by gently lifting up.
  5. Midland X-tra Talk Radio LXT118 Antenna Replacement, Antenna: passo 5, imagem 1 %32
    • Carefully and slowly lift the motherboard away from the front case. The motherboard will be attached to the speaker, which is firmly glued onto the front case.
  6. Midland X-tra Talk Radio LXT118 Antenna Replacement: passo 6, imagem 1 %32
    • Check the connection of the antenna with your eyes and fingers. The connection should be firm and smooth where it was soldered.
    • Ensure that the spring of the antenna isn't crooked or damaged by rubbing your fingers along the length of the spring.
    • Desolder the connection of the antenna to the motherboard. Careful!, if used improperly, the soldering tool can damage the circuit board!
  7. Midland X-tra Talk Radio LXT118 Antenna Replacement: passo 7, imagem 1 %32
    • After obtaining a new or undamaged spring, solder it back onto the circuit board. Again, this is a delacate process as the soldering tool will be hot!
Conclusão
5 outras pessoas executaram este guia.
Andre Nguyen
Membro desde: 01/18/13
108 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 19-43, Regan Winter 2013 Membro de Cal Poly, Team 19-43, Regan Winter 2013
CPSU-REGAN-W13S19G43
Membros da 3
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 18
Duração total: 2,098
