Ir para o conteúdo principal
Midea MRU03M2ABB Upright Freezer Door Replacement
O que você precisa
  1. Midea MRU03M2ABB Upright Freezer Door Replacement, Door: passo 1, imagem 1 %32 Midea MRU03M2ABB Upright Freezer Door Replacement, Door: passo 1, imagem 2 %32
    • Unplug the device.
    • Only unplug when your hand is dry.
  2. Midea MRU03M2ABB Upright Freezer Door Replacement: passo 2, imagem 1 %32
    • Empty the shelves.
  3. Midea MRU03M2ABB Upright Freezer Door Replacement: passo 3, imagem 1 %32 Midea MRU03M2ABB Upright Freezer Door Replacement: passo 3, imagem 2 %32 Midea MRU03M2ABB Upright Freezer Door Replacement: passo 3, imagem 3 %32
    • Use a plastic spatula to remove the hinge cover on top of the freezer.
    • Pushing at the pointy part of the cover makes it easier to remove.
  4. Midea MRU03M2ABB Upright Freezer Door Replacement: passo 4, imagem 1 %32 Midea MRU03M2ABB Upright Freezer Door Replacement: passo 4, imagem 2 %32 Midea MRU03M2ABB Upright Freezer Door Replacement: passo 4, imagem 3 %32
    • Unscrew the hinge counterclockwise.
  5. Midea MRU03M2ABB Upright Freezer Door Replacement: passo 5, imagem 1 %32 Midea MRU03M2ABB Upright Freezer Door Replacement: passo 5, imagem 2 %32
    • Lift the hinge out of the freezer and the door.
  6. Midea MRU03M2ABB Upright Freezer Door Replacement: passo 6, imagem 1 %32 Midea MRU03M2ABB Upright Freezer Door Replacement: passo 6, imagem 2 %32 Midea MRU03M2ABB Upright Freezer Door Replacement: passo 6, imagem 3 %32
    • With two hands, gently hold and open the door as usual.
    • Lift the door up to remove it from the bottom hinge.
    • You have completely detached the door from the freezer.
  7. Midea MRU03M2ABB Upright Freezer Door Replacement: passo 7, imagem 1 %32 Midea MRU03M2ABB Upright Freezer Door Replacement: passo 7, imagem 2 %32 Midea MRU03M2ABB Upright Freezer Door Replacement: passo 7, imagem 3 %32
    • With the new door, locate the hole underneath the door.
    • Using two hands, gently place the door on top of the hinge (the pointy part of the hinge should fit inside the hole).
    • Close the door.
  8. Midea MRU03M2ABB Upright Freezer Door Replacement: passo 8, imagem 1 %32 Midea MRU03M2ABB Upright Freezer Door Replacement: passo 8, imagem 2 %32 Midea MRU03M2ABB Upright Freezer Door Replacement: passo 8, imagem 3 %32
    • Use your hand to align the door so these three screw holes stay on the same line.
    • Carefully place the top hinge to fit these holes.
  9. Midea MRU03M2ABB Upright Freezer Door Replacement: passo 9, imagem 1 %32 Midea MRU03M2ABB Upright Freezer Door Replacement: passo 9, imagem 2 %32
    • Thread and tighten the screws clockwise.
    • Gently swing the door to make sure it operates well.
  10. Midea MRU03M2ABB Upright Freezer Door Replacement: passo 11, imagem 1 %32 Midea MRU03M2ABB Upright Freezer Door Replacement: passo 11, imagem 2 %32
    • Finally, firmly press the cover onto the hinge to secure it. Now, you have completely replaced the door.
    • A "click" will indicate that the cover is finally in its place.
Linha de Chegada
Thinh Lang
Membro desde: 01/16/24
193 Reputação
Autoria de 1 guia
1Comentário do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 48
Ao todo: 905
