Ir para o conteúdo principal
Microtek ScanMaker 5900 Stepper Motor Replacement
O que você precisa
  1. Microtek ScanMaker 5900 Stepper Motor Replacement, Remove serial port connection: passo 1, imagem 1 %32 Microtek ScanMaker 5900 Stepper Motor Replacement, Remove serial port connection: passo 1, imagem 2 %32 Microtek ScanMaker 5900 Stepper Motor Replacement, Remove serial port connection: passo 1, imagem 3 %32
    • Loosen the screws on the serial port by turning them counter clockwise by hand.
    • After loosening the screws, pull the serial port out.
  2. Microtek ScanMaker 5900 Stepper Motor Replacement, Remove Lid: passo 2, imagem 1 %32 Microtek ScanMaker 5900 Stepper Motor Replacement, Remove Lid: passo 2, imagem 2 %32 Microtek ScanMaker 5900 Stepper Motor Replacement, Remove Lid: passo 2, imagem 3 %32
    • Lift lid to its vertical position.
    • Pull lid straight up to remove it from the scanner.
  3. Microtek ScanMaker 5900 Stepper Motor Replacement, Detach plastic latches: passo 3, imagem 1 %32 Microtek ScanMaker 5900 Stepper Motor Replacement, Detach plastic latches: passo 3, imagem 2 %32 Microtek ScanMaker 5900 Stepper Motor Replacement, Detach plastic latches: passo 3, imagem 3 %32
    • Push the plastic opening tools into the crack between the top and the bottom of the chassis.
  4. Microtek ScanMaker 5900 Stepper Motor Replacement, Continue latch detachment: passo 4, imagem 1 %32 Microtek ScanMaker 5900 Stepper Motor Replacement, Continue latch detachment: passo 4, imagem 2 %32 Microtek ScanMaker 5900 Stepper Motor Replacement, Continue latch detachment: passo 4, imagem 3 %32
    • After placing one plastic opening tool into the slit, slide other plastic opening tools along the slit to detach the top from the bottom of the chassis.
    • Go all the way along the chassis until you can lift the upper lid.
  5. Microtek ScanMaker 5900 Stepper Motor Replacement, Fully remove the upper lid: passo 5, imagem 1 %32 Microtek ScanMaker 5900 Stepper Motor Replacement, Fully remove the upper lid: passo 5, imagem 2 %32 Microtek ScanMaker 5900 Stepper Motor Replacement, Fully remove the upper lid: passo 5, imagem 3 %32
    • Do not fully remove the lid until you remove the ribbon cable attached to the front of the upper lid.
    • Do this by grabbing the upper lid from the sides and rotating it ninety degrees so it is perpendicular to the bottom lid.
    • Grab the ribbon cable and gently pull it out of its slot with your fingers.
    • The upper lid can now safely be removed from the bottom lid.
  6. Microtek ScanMaker 5900 Stepper Motor Replacement, Stepper Motor: passo 6, imagem 1 %32 Microtek ScanMaker 5900 Stepper Motor Replacement, Stepper Motor: passo 6, imagem 2 %32
    • Locate the stepper motor. With the front of the scanner facing you, the motor is located at the top left.
    • Disconnect the white connector from the vertical standing circuit board.
  7. Microtek ScanMaker 5900 Stepper Motor Replacement: passo 7, imagem 1 %32 Microtek ScanMaker 5900 Stepper Motor Replacement: passo 7, imagem 2 %32 Microtek ScanMaker 5900 Stepper Motor Replacement: passo 7, imagem 3 %32
    • Using a #2 Philips Screwdriver, unscrew the two 7.7mm screws holding the stepper motor in place.
    • The stepper motor will become loose, but not completely free.
  8. Microtek ScanMaker 5900 Stepper Motor Replacement: passo 8, imagem 1 %32 Microtek ScanMaker 5900 Stepper Motor Replacement: passo 8, imagem 2 %32 Microtek ScanMaker 5900 Stepper Motor Replacement: passo 8, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Using tweezers gently remove the tread from the black gear on the stepper motor.
    • The stepper motor will become completely free.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 6-9, Regan Fall 2011 Membro de Cal Poly, Team 6-9, Regan Fall 2011
CPSU-REGAN-F11S6G9
2 Membros
Autoria de 22 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 11
Ao todo: 1,769
