Ir para o conteúdo principal
Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement
O que você precisa
  1. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove serial port connection: passo 1, imagem 1 %32 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove serial port connection: passo 1, imagem 2 %32 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove serial port connection: passo 1, imagem 3 %32
    • Loosen the screws on the serial port by turning them counter clockwise by hand.
    • After loosening the screws, pull the serial port out.
  2. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove Lid: passo 2, imagem 1 %32 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove Lid: passo 2, imagem 2 %32 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove Lid: passo 2, imagem 3 %32
    • Lift lid to its vertical position.
    • Pull lid straight up to remove it from the scanner.
  3. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the protective plastic covering: passo 3, imagem 1 %32 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the protective plastic covering: passo 3, imagem 2 %32 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the protective plastic covering: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Notice that there are two plastic tabs that need to be pushed in to remove the plastic covering.
    • Use tweezers to push these tabs in.
    • Gently pull the plastic covering off of the upper lid.
  4. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove wires from circuit board: passo 4, imagem 1 %32 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove wires from circuit board: passo 4, imagem 2 %32 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove wires from circuit board: passo 4, imagem 3 %32
    • Grab the plastic wire housing near the serial port.
    • Gently pull and jiggle the wire housing until it comes free from the circuit board.
  5. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the bulbs: passo 5, imagem 1 %32 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the bulbs: passo 5, imagem 2 %32
    • Gently lift up the bulbs and remove the wires from the plastic.
    • After completely freeing the bulbs, buy new ones and replace.
Conclusão
Taylor Nesheim
Membro desde: 10/11/11
59 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 6-9, Regan Fall 2011 Membro de Cal Poly, Team 6-9, Regan Fall 2011
CPSU-REGAN-F11S6G9
2 Membros
Autoria de 22 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 12
Ao todo: 1,272
