Ir para o conteúdo principal
Microsoft Zune HD Lower Rear Panel Replacement
O que você precisa
  1. Microsoft Zune HD Lower Rear Panel Replacement, Upper Rear Panel: passo 1, imagem 1 %32
    • Remove the four Tri-Wing screws securing the upper rear panel to the inner chassis.
  2. Microsoft Zune HD Lower Rear Panel Replacement: passo 2, imagem 1 %32 Microsoft Zune HD Lower Rear Panel Replacement: passo 2, imagem 2 %32
    • Slightly rotate the top edge of the upper rear panel away from the Zune.
    • Lift the upper rear panel straight up off the black plastic lower rear panel.
  3. Microsoft Zune HD Lower Rear Panel Replacement, Lower Rear Panel: passo 3, imagem 1 %32 Microsoft Zune HD Lower Rear Panel Replacement, Lower Rear Panel: passo 3, imagem 2 %32
    • Insert a small Zune opening tool into the gap between the logic board and one side of the black plastic lower rear panel.
    • Carefully twist the Zune opening tool to pop the lower rear panel off the clips attaching it to the Zune.
    • Repeat this process for the other side of the lower rear panel.
  4. Microsoft Zune HD Lower Rear Panel Replacement: passo 4, imagem 1 %32
    • Carefully slide the lower rear panel away from the Zune.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 3,114
