Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Microsoft Zune 80 Hard Drive Replacement
O que você precisa
  1. Microsoft Zune 80 Hard Drive Replacement, Case: passo 1, imagem 1 %32
    • Use a metal spudger or Zune opening tool to remove the small silver plastic cap on top of the device.
  2. Microsoft Zune 80 Hard Drive Replacement: passo 2, imagem 1 %32
    • There are two T3 screws under the cap. Remove both with a T3 screwdriver.
    • Be careful with removing these screws! These screwheads are prone to breaking.
  3. Microsoft Zune 80 Hard Drive Replacement, Remove the Casing: passo 3, imagem 1 %32 Microsoft Zune 80 Hard Drive Replacement, Remove the Casing: passo 3, imagem 2 %32
    • Using a metal spudger or Zune opening tool, remove the aluminum backing starting from the top. There are 5 clips on each side and two on the bottom.
    • Be careful not to press the tools in too far; there are exposed cables right inside the edge of the device.
  4. Microsoft Zune 80 Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32 Microsoft Zune 80 Hard Drive Replacement, Hard Drive: passo 4, imagem 2 %32
    • Remove the silver tape from the bottom center and the top right. This allows access to the hard drive and the battery.
  5. Microsoft Zune 80 Hard Drive Replacement: passo 5, imagem 1 %32 Microsoft Zune 80 Hard Drive Replacement: passo 5, imagem 2 %32 Microsoft Zune 80 Hard Drive Replacement: passo 5, imagem 3 %32
    • Unclick the black bar connecting the orange hard drive cable to the bottom of the hard drive. Gently push towards the bottom of the device on the black bar until you hear a click sound, it is now disengaged from the hard drive.
    • If the cable doesn't come off easily, the black bar has not been un-clicked.
    • Now gently pull the orange hard drive cable to remove it from the hard drive.
    • Lift the hard drive from the device.
    • Hard Drive Replacement Only: Check to make sure the hard drive cable is in good condition and then connect the new hard drive in the same place, following the steps in reverse order.
Conclusão
8 outras pessoas executaram este guia.
turey
Membro desde: 11/11/09
400 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 6-5, Maness Fall 2009 Membro de Cal Poly, Team 6-5, Maness Fall 2009
CPSU-MANESS-F09S6G5
Membros da 5
Autoria de 5 guias
Um comentário
what model hard drive did you utilize during its replacement?
thanksss
RAFI V DEMIRJIAN - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 40
Duração total: 12,519
