Ir para o conteúdo principal
Microsoft Zune 80 Case Replacement
O que você precisa
  1. Microsoft Zune 80 Case Replacement, Case: passo 1, imagem 1 %32
    • Use a metal spudger or Zune opening tool to remove the small silver plastic cap on top of the device.
  2. Microsoft Zune 80 Case Replacement: passo 2, imagem 1 %32
    • There are two T3 screws under the cap. Remove both with a T3 screwdriver.
    • Be careful with removing these screws! These screwheads are prone to breaking.
  3. Microsoft Zune 80 Case Replacement, Remove the Casing: passo 3, imagem 1 %32 Microsoft Zune 80 Case Replacement, Remove the Casing: passo 3, imagem 2 %32
    • Using a metal spudger or Zune opening tool, remove the aluminum backing starting from the top. There are 5 clips on each side and two on the bottom.
    • Be careful not to press the tools in too far; there are exposed cables right inside the edge of the device.
Conclusão
Uma outra pessoa concluiu este guia.
turey
Membro desde: 11/11/09
400 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 6-5, Maness Fall 2009 Membro de Cal Poly, Team 6-5, Maness Fall 2009
CPSU-MANESS-F09S6G5
Membros da 5
Autoria de 5 guias
Um comentário
I have followed these steps but im unable to get the back case off, any tips for a stubborn backing?
zippy9765 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 22
Duração total: 4,729
