Introdução
Use the guide to replace both or one of your broken or wasted thumbsticks in your Xbox Series X controller.
The thumbsticks are the central part of the controller that allows for most of your in-game movement. A wasted or broken thumbstick could reduce your performance for some of your favorite games.
Before using this guide, make sure to ensure that your thumbsticks are the ones wasted or broken because if it is stick drift, then this is not the correct guide for you to follow.
O que você precisa
Remove the battery pack cover.
If there are any batteries inside of it, remove them.
13 outras pessoas executaram este guia.
4 comentários
@aaron73239 , to fix the joystick drift, you might want to try this guide.
Perhaps it is this article? Xbox One Wireless Controller Model 1708 Button Replacement
Would be appreciated if someone with relevant knowledge or experience would confirm this.
Pictory -
