Ir para o conteúdo principal
Microsoft XBOX 360 Quick Charge Kit Bad Capacitor Replacement
O que você precisa
  1. Microsoft XBOX 360 Quick Charge Kit Bad Capacitor Replacement, Bad Capacitor causing charge to fail: passo 1, imagem 1 %32 Microsoft XBOX 360 Quick Charge Kit Bad Capacitor Replacement, Bad Capacitor causing charge to fail: passo 1, imagem 2 %32
    • Unit is glued together, making disassembly somewhat difficult. Using a utility knife, repeatedly score the plastic, top to bottom and all the way around, in the seam on the face, rear and bottom of the charger. The knife will begin to penetrate the charger.
  2. Microsoft XBOX 360 Quick Charge Kit Bad Capacitor Replacement: passo 2, imagem 1 %32
    • Using a spudger or similar stiff plastic tool, begin prying around the unit in the line that you previously scored, avoid having the tool go in to the device and damaging components. Eventually it will split apart.
  3. Microsoft XBOX 360 Quick Charge Kit Bad Capacitor Replacement: passo 3, imagem 1 %32
    • Note the bulging top of the failed capacitor. It's a 2200uf 6.3V available at any local TV repair shop.
    • De-solder it from the board noting the polarity. The side with the grey line is the negative that faces the heat sink.
  4. Microsoft XBOX 360 Quick Charge Kit Bad Capacitor Replacement: passo 4, imagem 1 %32
    • Resolder new capacitor in place, noting the correct polarity.
  5. Microsoft XBOX 360 Quick Charge Kit Bad Capacitor Replacement: passo 5, imagem 1 %32
    • Put unit back together, you can clamp or tape it together, and put some drops of crazy glue in the seam all the way around.
    • Remove claps / tape, plug in and enjoy your working Quick Charger.
Conclusão
Game on!
4 outras pessoas executaram este guia.
Richard Martel
Membro desde: 02/09/13
373 Reputação
Autoria de 1 guia
Um comentário
I just completed disassembly. It isn't necessary to cut into the seam. Instead, use the blade of a putty knife as a lever. Insert the putty knife into the seam/groove, and gently pry the two halves away from each other. You'll hear the glue start to crack with little or no damage to the plastic. Repeat all the way around. It may be necessary to use a second putty knife, or a thicker similar tool, as the gap begins to widen. Just keep prying in this way until the two peices are free. Don't use a screwdriver... It will just ding the plastic. Also be sure to cut the label on the bottom first (a razor blade or exacto knife makes a nice clean cut).
mtkohl85 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 19
Duração total: 5,903
