Ir para o conteúdo principal
Microsoft Surface Speakers Replacement
O que você precisa
  1. Microsoft Surface Speakers Replacement, Back Cover: passo 1, imagem 1 %32 Microsoft Surface Speakers Replacement, Back Cover: passo 1, imagem 2 %32 Microsoft Surface Speakers Replacement, Back Cover: passo 1, imagem 3 %32
    • Prior to any repairs make sure that the device is orientated correctly, and you are familiar with all ports and buttons. The screen should be facing up with the Windows logo located on the bottom.
    • Turn off device prior to continuing
  2. Microsoft Surface Speakers Replacement: passo 2, imagem 1 %32 Microsoft Surface Speakers Replacement: passo 2, imagem 2 %32 Microsoft Surface Speakers Replacement: passo 2, imagem 3 %32
    • Carefully turn the tablet over so the screen is facing down.
    • Pull up on the bottom corners to open the stand.
  3. Microsoft Surface Speakers Replacement: passo 3, imagem 1 %32 Microsoft Surface Speakers Replacement: passo 3, imagem 2 %32
    • Remove the two 5.1 mm T5 Torx screws.
    • The two screws will be located on the left and right sides in the kickstand.
    • Make sure when removing the screws to be careful to prevent stripping of the head.
    • With all the screws removed gently wiggle the stand side to side until the lever in the middle is free, releasing the stand.
  4. Microsoft Surface Speakers Replacement: passo 4, imagem 1 %32 Microsoft Surface Speakers Replacement: passo 4, imagem 2 %32
    • Use a spudger or similar flat headed tool to release the small bezels out lined in the image. Remove the plastic trim covering the camera with the soft flat headed tool.
    • Be patient; you will have to work around the casing because there are several small bezels along the edges.
  5. Microsoft Surface Speakers Replacement: passo 5, imagem 1 %32 Microsoft Surface Speakers Replacement: passo 5, imagem 2 %32
    • Next, remove the ten 5.92mm T5 torx screws located underneath the kickstand.
    • Remove the seven 5.87mm T5 torx screws located under the camera casing. There is a sticker covering the second screw from the left.
    • Disconnect the rear cover from the main shell of the system by loosening it with a spudger where the gaps exist.
    • There is an electrical ribbon connecting the rear cover to the motherboard. Do not pull apart the rear cover from the motherboard once you have loosened the rear cover from the main system.
    • Continue working your way around to each corner and loosen the snap-ons on each side until the rear cover comes off.
  6. Microsoft Surface Speakers Replacement: passo 6, imagem 1 %32 Microsoft Surface Speakers Replacement: passo 6, imagem 2 %32 Microsoft Surface Speakers Replacement: passo 6, imagem 3 %32
    • Rotate the device 180 degrees so that the bottom of the device is facing you.
    • A ribbon connects the battery on the rear cover, to the motherboard. Slowly lift the bottom of the rear cover up until you can see the ribbon.
    • Use a spudger to push the ribbon away from the motherboard and parallel to the motherboard in order to remove the ribbon.
    • Separate the rear cover by lifting it up away from the main system.
    • When reassembling the rear cover to the motherboard, reinserting the ribbon cable with a spudger may prove difficult. In this case, gently use your hands to slide the cable end into the slot until they click into place.
  7. Microsoft Surface Speakers Replacement, Speakers: passo 7, imagem 1 %32 Microsoft Surface Speakers Replacement, Speakers: passo 7, imagem 2 %32
    • Locate the two speakers on the left and right sides of the motherboard.
    • Use a spudger to remove the orange ribbon connected to the motherboard located on the left.
    • Make to remove the ribbon from the specified side.
  8. Microsoft Surface Speakers Replacement: passo 8, imagem 1 %32 Microsoft Surface Speakers Replacement: passo 8, imagem 2 %32 Microsoft Surface Speakers Replacement: passo 8, imagem 3 %32
    • On the motherboard, locate where the orange ribbon of the speakers is connected to the motherboard and flip the white switch upwards so that it is perpendicular to the motherboard.
    • Loosen the speakers from the motherboard using a spudger.
    • Gently pull out the speaker's electrical ribbon from the motherboard for both speakers.
    • Both speakers need to be detached the same way. This will allow the speakers to be removed more easily.
Conclusão
Uma outra pessoa concluiu este guia.
Kevin Hua
Membro desde: 01/11/13
1.657 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 17-23, Forte Winter 2013 Membro de Cal Poly, Team 17-23, Forte Winter 2013
CPSU-FORTE-W13S17G23
Membros da 5
Autoria de 17 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 2,707
