Ir para o conteúdo principal
Microsoft Surface Pro X SSD and SIM Card Door Removal
O que você precisa
  1. Microsoft Surface Pro X SSD and SIM Card Door Removal, Open the kickstand: passo 1, imagem 1 %32 Microsoft Surface Pro X SSD and SIM Card Door Removal, Open the kickstand: passo 1, imagem 2 %32
    • Make sure your Surface Pro X is turned off, and laying screen-side down on a soft surface.
    • After turning off your device, make sure to remove the SSD from the Surface before starting any repairs. This will disconnect the battery and prevent damage to the device.
    • Lift the kickstand to at least a 90° angle, so that it is perpendicular to the Surface's screen. The further you open the hinge, the easier it is to access the SSD and SIM card door.
  2. Microsoft Surface Pro X SSD and SIM Card Door Removal, Open the SSD and SIM card door: passo 2, imagem 1 %32 Microsoft Surface Pro X SSD and SIM Card Door Removal, Open the SSD and SIM card door: passo 2, imagem 2 %32
    • Insert a SIM card eject tool or a paperclip into the small hole in the bottom right corner of the SSD and SIM card door, located near the bottom right corner of the Surface.
    • Press firmly to open the door.
  3. Microsoft Surface Pro X SSD and SIM Card Door Removal, Remove the SSD and SIM card door: passo 3, imagem 1 %32
Conclusão
Uma outra pessoa concluiu este guia.
Adam O'Camb
Membro desde: 04/11/15
199.413 Reputação
Autoria de 416 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 23
Últimos 30 dias: 128
Duração total: 9,811
