Pular para o conteúdo principal
Introdução
*In order to access the charging port, refer to steps 1 - 6 in the Microsoft Surface Pro Teardown Guide to remove the screen.
Teardown Guide
  1. Using a T5 Torx screwdriver, unscrew a total number of 23 screws located on the outside panel of the Surface Pro. Using a T5 Torx screwdriver, unscrew a total number of 23 screws located on the outside panel of the Surface Pro.
    • Using a T5 Torx screwdriver, unscrew a total number of 23 screws located on the outside panel of the Surface Pro.
  2. Use the plastic opening tool or fingers to pry out the front camera.
    • Use the plastic opening tool or fingers to pry out the front camera.
  3. Lift the outside panel from the Surface Pro
    • Lift the outside panel from the Surface Pro
  4. PC Laptop Batteries
    An easy fix for a big power boost.
    Comprar agora
    PC Laptop Batteries
    Comprar agora
  5. Use the T5 torx screw driver to unscrew the 6 T5 screws in the left and right outside metal panels Use the T2 torx screw driver to unscrew the 23 T2 screws on the left and right outside metal panels
    • Use the T5 torx screw driver to unscrew the 6 T5 screws in the left and right outside metal panels
    • Use the T2 torx screw driver to unscrew the 23 T2 screws on the left and right outside metal panels
  6. Pull out left and right metal panels with hands
    • Pull out left and right metal panels with hands
  7. Pull out the orange charging port strip using tweezers
    • Pull out the orange charging port strip using tweezers
  8. Unscrew the two T5 torx screws located on each side of the charging port.
    • Unscrew the two T5 torx screws located on each side of the charging port.
  9. Once you have unscrewed the charging port, you can gently pull it out with your hands.
    • Once you have unscrewed the charging port, you can gently pull it out with your hands.
Conclusão
Uma outra pessoa concluiu este guia.
Jonathan Choi
Membro desde: 09-10-2013
660 reputação
4 Guias de autoria
Equipe
Cal Poly, Team 8-20, Regan Fall 2013 Membro de Cal Poly, Team 8-20, Regan Fall 2013
CPSU-REGAN-F13S8G20
4 Membros
10 Guias de autoria
Where do you get a replacement charging port at?
Evil Robot - Responder
Agree where can you get the port?
J-M. M. - Responder
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 47
Últimos 30 dias: 238
Todo: 12,031
