Ir para o conteúdo principal
Microsoft Surface Pro 4 SSD Drive Replacement
O que você precisa
  1. Microsoft Surface Pro 4 SSD Drive Replacement, SSD Drive: passo 1, imagem 1 %32 Microsoft Surface Pro 4 SSD Drive Replacement, SSD Drive: passo 1, imagem 2 %32
    • Use a blue plastic opening tool to pry around the edges of the metal shield covering the SSD drive.
  2. Microsoft Surface Pro 4 SSD Drive Replacement: passo 2, imagem 1 %32 Microsoft Surface Pro 4 SSD Drive Replacement: passo 2, imagem 2 %32
    • Remove the 1.0 mm Torx T4 screw holding down the SSD drive.
  3. Microsoft Surface Pro 4 SSD Drive Replacement: passo 3, imagem 1 %32 Microsoft Surface Pro 4 SSD Drive Replacement: passo 3, imagem 2 %32
    • Use a blue plastic opening tool or spudger to lift the SSD drive slightly and grasp it with your fingers. Pull the drive down towards yourself to remove it from the device.
Conclusão
92 outras pessoas executaram este guia.
StacyAnn Brown
Membro desde: 01/15/16
3.985 Reputação
Autoria de 2 guias
Equipe
Metro State, Team 1-3, Carpenter Spring 2016 Membro de Metro State, Team 1-3, Carpenter Spring 2016
MSU-CARPENTER-S16S1G3
2 Membros
Autoria de 12 guias
46Comentários do guia
Can you add more SSD to the SP4??
dudu93lokao - Responder
Where can I buy a 1T that is compatible with it?
izou1838 - Responder
You can probably replace it with any 1TB NVMe M.2 SSD you find at any retailer. You can find plenty of those on Amazon.
Tip: Look for the performance models, such as Samsung PRO or similar.
Nmindz -
I would love to upgrade my storage while repairing my broken screen, does anyone know of which sdd would be compatible with my i7 8gb ram 256ssd right now? Does it have to be a samsung ssd or are there other options. Fairly new to computer repair here so would love some experienced advice thanks !
I would prefer a 1TB if possible but would settle for a 512 also.
bthonre - Responder
@bthorne As long as it's the same connection (not sure, but maybe you should look for NVMe M.2 SSD) it should work without problems. You should run a quick search on the internet to check if anyone has found some sort of "blacklisted" parts (some vendors such as Lenovo used to place some code in their firmware which would prevent the computer from booting with a "unauthorized" wireless card for example.).
However I think this is not the case with the Surface Pro 4 or the world would be at rage right now. Just look for any size NVMe M.2 SSD you think it would be fit (if you can afford, look for performance models such as Samsung PRO, there's a huge difference from the cheaper ones.). Hope it helps!
Nmindz -
Comentar
Visualizações:
Últimas 24 horas: 26
Últimos 7 dias: 212
Últimos 30 dias: 1,055
Ao todo: 281,244
