Ir para o conteúdo principal
Microsoft Surface Pro 3 Kickstand Replacement
O que você precisa
  1. Microsoft Surface Pro 3 Kickstand Replacement, Kickstand: passo 1, imagem 1 %32
    • Lift the kickstand to a 90º angle to expose the hinge screws.
  2. Microsoft Surface Pro 3 Kickstand Replacement: passo 2, imagem 1 %32 Microsoft Surface Pro 3 Kickstand Replacement: passo 2, imagem 2 %32
    • Remove the four 3.5 mm T5 screws—two on each side.
  3. Microsoft Surface Pro 3 Kickstand Replacement: passo 3, imagem 1 %32 Microsoft Surface Pro 3 Kickstand Replacement: passo 3, imagem 2 %32
    • Wiggle the kickstand gently back and forth to disengage the two lightly-adhered tabs connecting the center of the kickstand to the main body.
    • Remove the kickstand from the back cover of the Surface Pro 3.
Conclusão
Sarah Westberg
Membro desde: 03/11/19
24.109 Reputação
Autoria de 71 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 141
Autoria de 17.895 guias
2 comentários
The title for this repair guide is incorrect. This is for the kickstand, not the battery.
Michael Kavanaugh - Responder
Hi Michael, thanks for catching this! It looks like someone changed it and it was ok’d on accident. We’ve changed it back.
Sarah Westberg -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 47
Duração total: 4,281
