Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Microsoft Surface Pro 11, use o nosso manual de serviço.
  1. Microsoft Surface Pro 11 Chip ID, Main Board Side 1: passo 1, imagem 1 %32 Microsoft Surface Pro 11 Chip ID, Main Board Side 1: passo 1, imagem 2 %32
    • Qualcomm X1P-64-100-103 Snapdragon X Plus deca-core applications processor
    • SK hynix H58G56BK8BX068 4 GB LPDDR5X SDRAM Memory
    • Qualcomm PMC8380-001-00 power management
    • Qualcomm PMC8380VE-001 power management
    • Qualcomm PMC1010H-001-07 charge pump & buck regulator
    • Qualcomm PMC1010H-001-08 charge pump & buck regulator
    • Qualcomm power management
  2. Microsoft Surface Pro 11 Chip ID: passo 2, imagem 1 %32
    • Qualcomm SMB2360-002 battery charger
    • Qualcomm SMB2361-002 battery charger
    • Likely Qualcomm clock generator
    • Parade Technologies PS8830 USB4, DisplayPort 2.0, and Thunderbolt 3.0 retimer
    • Murata PE23108 LED backlight driver
    • Qualcomm audio amplifier
    • Analog Devices MAX34417 current & voltage monitor
  3. Microsoft Surface Pro 11 Chip ID: passo 3, imagem 1 %32
    • Monolithic Power Systems MP2322 1 A synchronous step-down converter
    • Richtek RT5753ALGQW 3 A synchronous step-down converter
    • Monolithic Power Systems DC-DC converter
    • Nexperia 74LVC2G66 dual SPST analog switch
    • Texas Instruments TPS22964C 3 A load switch
    • Diodes Incorporated AP22653FDZ-7 adjustable current-limited power distribution switch
  4. Microsoft Surface Pro 11 Chip ID: passo 4, imagem 1 %32
    • NXP Semiconductors NX3P1108UK high-side power switch
    • Toshiba TCR3UM18A 300 mA / 1.8 V LDO regulator
    • Texas Instruments SN74LV1T08 single 2-input AND gate
    • Diodes Incorporated 74AUP1G08FS3 single 2-input AND gate
  5. Microsoft Surface Pro 11 Chip ID, Main Board Side 1 - Connectivity: passo 5, imagem 1 %32
    • Qualcomm WCN7851-501 FastConnect 7800 WiFi 7 & Bluetooth 5.4 controller
    • Qualcomm 2.4 GHz front-end module
    • Qualcomm 5 GHz front-end module
  6. Microsoft Surface Pro 11 Chip ID, Main Board Side 1 - Filters: passo 6, imagem 1 %32
    • Qualcomm B7530 Bluetooth/WLAN SAW filter
  7. Microsoft Surface Pro 11 Chip ID, Main Board Side 2: passo 7, imagem 1 %32 Microsoft Surface Pro 11 Chip ID, Main Board Side 2: passo 7, imagem 2 %32
    • NXP Semiconductors MIMXRT633SFFOB 32-bit ARM Cortex-M33 microcontroller w/ Xtensa HiFi4 audio DSP
    • Winbond W25Q512NW 64 MB serial NOR flash memory
    • Macronix MX25U1633FZUI 2 MB serial NOR flash memory
    • Renesas mixed signal array
    • Likely Qualcomm camera power management
    • NXP Semiconductors NX20P0407UK USB type-C port protector
    • Analog Devices MAX4983EEVB+ USB 2.0 DPDT analog switch
  8. Microsoft Surface Pro 11 Chip ID: passo 8, imagem 1 %32
    • Vishay DG2723 dual SPDT analog switch
    • onsemi FPF2495CUCX 28 V over-voltage & over-current protection load switch
    • Diodes Incorporated AP22800HB-7 programmable load switch
  9. Microsoft Surface Pro 11 Chip ID: passo 9, imagem 1 %32
    • NXP Semiconductors PCA9306 2-bit voltage-level translator
    • Nexperia 74AVC2T245 2-bit level shifter
    • Nexperia 74LV1T08GX single 2-input AND gate
  10. Microsoft Surface Pro 11 Chip ID, Main Board Side 2 - Sensors: passo 10, imagem 1 %32
    • STMicroelectronics LSM6DSO 6-axis accelerometer & gyroscope
    • STMicroelectronics LIS2DW12 3-axis accelerometer
    • MEMSIC MMC5633NJL 3-axis magnetometer
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 72
Últimos 7 dias: 352
Últimos 30 dias: 1,112
Duração total: 1,112
