Ir para o conteúdo principal
Microsoft Surface RT Kick-stand Replacement
O que você precisa
  1. Microsoft Surface RT Kick-stand Replacement, Kick-stand: passo 1, imagem 1 %32 Microsoft Surface RT Kick-stand Replacement, Kick-stand: passo 1, imagem 2 %32
    • Turn the tablet over so the screen is facing down.
    • Pull up on the bottom corners to open the stand.
    • Remove the stand by unscrewing the two 5.08mm T5 Torx screws located on the left and right sides.
    • Gently wiggle the stand until the lever in the middle is free, releasing the stand.
Conclusão
13 outras pessoas executaram este guia.
Kevin Hua
Membro desde: 01/11/13
1.615 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 17-23, Forte Winter 2013 Membro de Cal Poly, Team 17-23, Forte Winter 2013
CPSU-FORTE-W13S17G23
Membros da 5
Autoria de 17 guias
12 comentários
Where do you get the replacement kickstand from?
Ray - Responder
is this compatible with surface pro 1 ?
arqueiro - Responder
Do you offer a replacement kickstand for the surface rt 2?
allie - Responder
Does this replacement kickstand come with the screws also?
Andrea Thompson - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 30
Duração total: 40,584
