Introdução
The Microsoft Surface Headphones headband cushion allows for a comfortable listening experience. If you've noticed that the cushioning doesn't seem so comfortable anymore, it might be time to replace it. This guide will show you how to do just that!
O que você precisa
Starting at the peak of the headband, push inward below the seam, between the plastic headband and cushion, to create a gap.
Work your way down the headband until the cushion is exposed.
3 outras pessoas executaram este guia.
2 comentários
How do you put back the the cushion cover?
