Ir para o conteúdo principal
Microsoft Surface Book 2 15" Heat Sink Replacement
  1. Microsoft Surface Book 2 15" Heat Sink Replacement, Motherboard: passo 1, imagem 1 %32
    • Open the laptop, then orient it so the touchpad is on your left.
    • Starting at the hinge, count six holes up on the tablet portion of the laptop.
  2. Microsoft Surface Book 2 15" Heat Sink Replacement: passo 2, imagem 1 %32 Microsoft Surface Book 2 15" Heat Sink Replacement: passo 2, imagem 2 %32
    • Take a paper clip and unfold it.
    • Place the paperclip in the sixth hole and push until you hear a click.
    • Once you hear the click, lift up on the right side of the tablet from the base until it separates.
    • After the right side has been detached, lift up the left side as well.
  3. Microsoft Surface Book 2 15" Heat Sink Replacement: passo 3, imagem 1 %32
    • Place the tablet on a flat surface.
    • Using a heat gun or iOpener, heat up the edges of the screen to soften up the adhesive.
  4. Microsoft Surface Book 2 15" Heat Sink Replacement: passo 4, imagem 1 %32
    • Using a plastic pick, slice underneath the edge of the screen.
    • Use a suction cup to carefully lift the screen and create separation between the screen and frame.
    • Take care not to insert the tool too far to avoid cutting the ribbon cables.
    • Slowly make your way around the screen, and carefully cut the adhesive that secures the screen to the frame.
    • Don't use a metal tool, that could damage the screen or internal parts.
  5. Microsoft Surface Book 2 15" Heat Sink Replacement: passo 5, imagem 1 %32 Microsoft Surface Book 2 15" Heat Sink Replacement: passo 5, imagem 2 %32
    • Lift up the screen.
    • Detach the ribbon cables connecting the underside of the screen to the motherboard.
  6. Microsoft Surface Book 2 15" Heat Sink Replacement: passo 6, imagem 1 %32 Microsoft Surface Book 2 15" Heat Sink Replacement: passo 6, imagem 2 %32
    • Use a T3 Torx screwdriver to remove eleven 4 mm screws from the motherboard.
    • Use a T3 Torx screwdriver to remove the ten 2.5 mm screws from the top bar.
  7. Microsoft Surface Book 2 15" Heat Sink Replacement: passo 7, imagem 1 %32
    • Once the screws are removed from the top bar, gently lift up and remove it.
    • Be careful not to damage any ribbon cables or wires.
    • Gently lift up on the motherboard to remove it.
  8. Microsoft Surface Book 2 15" Heat Sink Replacement, Heat Sink: passo 8, imagem 1 %32 Microsoft Surface Book 2 15" Heat Sink Replacement, Heat Sink: passo 8, imagem 2 %32
    • With the motherboard removed flip it over.
  9. Microsoft Surface Book 2 15" Heat Sink Replacement: passo 9, imagem 1 %32 Microsoft Surface Book 2 15" Heat Sink Replacement: passo 9, imagem 2 %32
    • Remove the 4 torx 3 2.5mm screws holding in the heatsink.
    • Lift up and remove the heatsink. This requires a small amount of force.
Conclusão
Ryan Picewick
Membro desde: 03/13/23
480 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 3-3, Petersen Spring 2023 Membro de UMass Dartmouth, Team 3-3, Petersen Spring 2023
UMASSD-PETERSEN-S23S3G3
Membros da 4
Autoria de 23 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 46
Duração total: 519
