Ir para o conteúdo principal
Microsoft Lumia 640 XL Touch Screen Replacement
O que você precisa
  1. Microsoft Lumia 640 XL Touch Screen Replacement, Battery: passo 1, imagem 1 %32 Microsoft Lumia 640 XL Touch Screen Replacement, Battery: passo 1, imagem 2 %32 Microsoft Lumia 640 XL Touch Screen Replacement, Battery: passo 1, imagem 3 %32
    • Place left palm on screen and right palm on the back.
    • Press down with fingertips and pull to separate the back from the screen.
    • You may hear cracking and popping.
  2. Microsoft Lumia 640 XL Touch Screen Replacement: passo 2, imagem 1 %32 Microsoft Lumia 640 XL Touch Screen Replacement: passo 2, imagem 2 %32
    • Lift the battery away from the phone with the flat side of a spudger.
    • Be careful not to damage the battery.
  3. Microsoft Lumia 640 XL Touch Screen Replacement, Headphone Jack: passo 3, imagem 1 %32 Microsoft Lumia 640 XL Touch Screen Replacement, Headphone Jack: passo 3, imagem 2 %32 Microsoft Lumia 640 XL Touch Screen Replacement, Headphone Jack: passo 3, imagem 3 %32
    • Remove all ten T3, 4.09 mm screws.
    • Lift mid-frame assembly from phone with flat side of a spudger.
  4. Microsoft Lumia 640 XL Touch Screen Replacement: passo 4, imagem 1 %32 Microsoft Lumia 640 XL Touch Screen Replacement: passo 4, imagem 2 %32 Microsoft Lumia 640 XL Touch Screen Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Lift and peel connector away from phone using tweezers.
    • To re-attach you may need E6000 Adhesive Glue.
  5. Microsoft Lumia 640 XL Touch Screen Replacement, Motherboard: passo 5, imagem 1 %32 Microsoft Lumia 640 XL Touch Screen Replacement, Motherboard: passo 5, imagem 2 %32
    • Remove all three T3, 2.66 mm screws.
  6. Microsoft Lumia 640 XL Touch Screen Replacement: passo 6, imagem 1 %32 Microsoft Lumia 640 XL Touch Screen Replacement: passo 6, imagem 2 %32 Microsoft Lumia 640 XL Touch Screen Replacement: passo 6, imagem 3 %32
    Comprar
    • Lift off connector with tweezers.
    • Lift motherboard off with tweezers and pull away with fingers.
  7. Microsoft Lumia 640 XL Touch Screen Replacement, Touch Screen: passo 7, imagem 1 %32 Microsoft Lumia 640 XL Touch Screen Replacement, Touch Screen: passo 7, imagem 2 %32
    • Remove the screen from the device.
    • Touch screen digitizer and screen glass are one unit.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 14
Duração total: 1,209
