Introdução
Microsoft Lumia 535
RM-1090 / RM-1091/ RM-1089 / RM-1092
How to disassemble the phone and replace broken, smashed Display or Touch Screen Glass Digitizer.
!!!There are different versions touch screens:
• CT2S1973FPC-A1-E
• CT2C1607FPC-A1-E
The version is printed on the flex cable.
O que você precisa
Vídeo de Apresentação
Turn off the phone.
Remove the battery and any SIM and memory cards.
Disconnect:
Touch screen flex cable
LCD Display flex cable
Charging Dock board flex cable - remove the foam and tape, then flip up the black lock before easing out the flex.
Coaxial antena cable - take your time here, be sure to pull the metal connector and not the cable or you risk pulling the cable from the connector.
Remove the 2x Torx T4 screws.
Remove the display flex cable rubber.
Put scotch tape on glass to prevent it from shattering.
Use a hair dryer or heat gun and warm the glass to make adhesive soft.
50 outras pessoas executaram este guia.
19 comentários
hi
cane you tell me price of out glass of lumia 535 duol sim please ?!
I want to join in your team
Hi,How to know which the versions touch screens my phone is Lumia 535 RM-1089 , please?
