Ir para o conteúdo principal
Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement
O que você precisa
Vídeo de Apresentação
  1. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Back Cover / Rear Case: passo 1, imagem 1 %32 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Back Cover / Rear Case: passo 1, imagem 2 %32
    • Turn off the phone.
    • Remove the battery and any SIM and memory cards.
  2. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: passo 2, imagem 1 %32 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: passo 2, imagem 2 %32
    • With a screwdriver Torx T4 remove the 9x screws.
  3. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: passo 3, imagem 1 %32 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: passo 3, imagem 2 %32 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: passo 3, imagem 3 %32
    • With a plastic opening tool separate the back cover from the middle frame.
  4. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Logic board: passo 4, imagem 1 %32 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Logic board: passo 4, imagem 2 %32 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Logic board: passo 4, imagem 3 %32
    • Disconnect:
    • Touch screen flex cable
    • LCD Display flex cable
    • Charging Dock board flex cable - remove the foam and tape, then flip up the black lock before easing out the flex.
    • Coaxial antena cable - take your time here, be sure to pull the metal connector and not the cable or you risk pulling the cable from the connector.
    • Remove the 2x Torx T4 screws.
  5. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: passo 5, imagem 1 %32 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: passo 5, imagem 2 %32 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: passo 5, imagem 3 %32
    • Insert wisdom here.
  6. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Charging Port Dock and Microphone Flex: passo 6, imagem 1 %32 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Charging Port Dock and Microphone Flex: passo 6, imagem 2 %32 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Charging Port Dock and Microphone Flex: passo 6, imagem 3 %32
    • Disconnect the coaxial antenna cable.
    • The cable is attached at several points to the frame and to the board. Gently remove it.
  7. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: passo 7, imagem 1 %32 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: passo 7, imagem 2 %32 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: passo 7, imagem 3 %32
    • The board is glued to the main frame by adhesive tape.
    • Use a hot gun or hair dryer and warm the board.
    • Now you can easy separate the board from the main frame.
    • For the separation process use only plastic tools.
Conclusão
16 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
191.278 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.532 guias
Um comentário
where can i get charging port for microsoft lumia 540
saurabh pawar - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 14,760
