Introdução
Lumia 435 RM1068, RM-1069, RM1070, RM-1071
Lumia 532 RM-1032, RM1034
How to disassemble Lumia 435, Lumia 532 and replace the broken touch screen glass.
O que você precisa
Vídeo de Apresentação
Switch off the phone.
Remove the battery and any inserted SIM and memory cards.
Use a screwdriver Torx T6 and remove the 4x black screws.
Unhook:
the touch screen flex cable
the LCD Display flex cable
Use a plastic tool lift up and remove the Logic board.
The Display metal shield is locked to the frame by 4x locking clips.
Use a tool with a sharp tip and careful unlock them and remove the shield.
Put some transparent scotch tape to prevent the glass from shattering.
Warm the glass for a minute to make adhesive soften.
Start the separation from the middle of the frame, where the contact area is smaller.
5 outras pessoas executaram este guia.
Um comentário
Is the lcd adhesive just on the edges of the lcd or covering the entire thing?
