Ir para o conteúdo principal
Microsoft Lumia 435 Logic board Replacement
O que você precisa
Vídeo de Apresentação
  1. Microsoft Lumia 435 Logic board Replacement, Back Cover: passo 1, imagem 1 %32 Microsoft Lumia 435 Logic board Replacement, Back Cover: passo 1, imagem 2 %32 Microsoft Lumia 435 Logic board Replacement, Back Cover: passo 1, imagem 3 %32
    • Switch off the phone.
    • Remove the battery and any inserted SIM and memory cards.
    • Use a screwdriver Torx T6 and remove the 4x black screws.
  2. Microsoft Lumia 435 Logic board Replacement: passo 2, imagem 1 %32 Microsoft Lumia 435 Logic board Replacement: passo 2, imagem 2 %32 Microsoft Lumia 435 Logic board Replacement: passo 2, imagem 3 %32
    • There are several plastic locking clips hold the back cover to the frame.
    • Use a tool with a sharp edge to unlock them and a plastic tool to separate the back cover.
  3. Microsoft Lumia 435 Logic board Replacement, Logic board: passo 3, imagem 1 %32 Microsoft Lumia 435 Logic board Replacement, Logic board: passo 3, imagem 2 %32 Microsoft Lumia 435 Logic board Replacement, Logic board: passo 3, imagem 3 %32
    • Unhook:
    • the touch screen flex cable
    • the LCD Display flex cable
    • Use a plastic tool lift up and remove the Logic board.
  4. Microsoft Lumia 435 Logic board Replacement: passo 4, imagem 1 %32 Microsoft Lumia 435 Logic board Replacement: passo 4, imagem 2 %32
    • This is the logic board / main board - a front and rear view.
Conclusão
5 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
194.093 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
327 Membros
Autoria de 1.699 guias
2 comentários
كيف اقوم بفك الهاتف وفحص الخلل الذي يوجد فيه .اعني ان هاتفي لا يقبل العمل اظن انه محروق كيف افحصه ؟
How do I remove the phone and to inspect the defect in which the .ani there is a telephone that does not accept the work I think it's seared how it checked ?
mohammad7salaheddin - Responder
I need dead boatd off lumia 435
Azhar from lahore chung
Muhammad Azhar - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 10
Ao todo: 1,941
