Ir para o conteúdo principal
Microsoft Band Battery Replacement
O que você precisa
  1. Microsoft Band Battery Replacement, Battery: passo 1, imagem 1 %32
    • Unscrew both side panel 2mm screws using the T3 Torx screwdriver.
  2. Microsoft Band Battery Replacement: passo 2, imagem 1 %32
    • Firmly pry up the side panel using the plastic spudger to break the waterproof seal and lift the battery panel.
  3. Microsoft Band Battery Replacement: passo 3, imagem 1 %32
    • Gently pry up one edge of the battery with the plastic spudger.
  4. Microsoft Band Battery Replacement: passo 4, imagem 1 %32
    • Remove battery from its compartment with your fingers.
Conclusão
To reassemble your device, follow these instructions in reverse order. Replace the vibrator in its original compartment.
4 outras pessoas executaram este guia.
Monique Salinger
Membro desde: 02/01/15
390 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 17-34, Amido Winter 2015 Membro de Cal Poly, Team 17-34, Amido Winter 2015
CPSU-AMIDO-W15S17G34
Membros da 4
Autoria de 6 guias
5 comentários
where can i buy the battery?
chirac - Responder
From what I can tell it's something like this:
http://www.alibaba.com/product-detail/Ho...
which is a 3.7v flat lithium ion polymer 72mAh battery. Min order is 1030 though! You can find similar on AliExpress if you search for that description. The dimensions are listed as 4*14.8*21.5mm so it'll need to be within that, or maybe the OP can confirm the battery size?
Simon -
Will this be dangerous?
Rei zzstu Shiozawa - Responder
Anyway to upgrade to a higher capacity battery to get better life out of it? With GPS on, it dies in 2 hours and I go on 8 hr hikes.
Chris Green - Responder
No tak wszystko fajnie ale gdzie te akumulatory zakupić ?
Tomasz Sot - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 19
Duração total: 11,965
