Ir para o conteúdo principal
Microsoft Band 2 Battery Replacement
O que você precisa
  1. Microsoft Band 2 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Peel back the metal cover on the end of the watchband.
  2. Microsoft Band 2 Battery Replacement: passo 2, imagem 1 %32
    • Use a T3 Torx screwdriver to unscrew the four 6 mm screws on the corners of the metal cover plate.
  3. Microsoft Band 2 Battery Replacement: passo 3, imagem 1 %32
    • Use the plastic opening tool to pry off the metal cover plate.
  4. Microsoft Band 2 Battery Replacement: passo 4, imagem 1 %32 Microsoft Band 2 Battery Replacement: passo 4, imagem 2 %32
    • Detach the black ribbon cable by using the tweezers.
  5. Microsoft Band 2 Battery Replacement: passo 5, imagem 1 %32 Microsoft Band 2 Battery Replacement: passo 5, imagem 2 %32
    • Detach the orange press-fit (or "pop") connector by using the tweezers.
  6. Microsoft Band 2 Battery Replacement: passo 6, imagem 1 %32 Microsoft Band 2 Battery Replacement: passo 6, imagem 2 %32
    • Pry out the battery using the plastic opening tool.
Conclusão
20 outras pessoas executaram este guia.
Chris Syracuse
Membro desde: 02/20/17
639 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S1-G5, Leahy Spring 2017 Membro de USF Tampa, Team S1-G5, Leahy Spring 2017
USFT-LEAHY-S17S1G5
Membros da 3
Autoria de 5 guias
14 comentários
My Band 2 is not charging and it showing empty battery with AC plugin Icon, but after longtime its not charging . In this case if I replace the battery is it will work or not?
Notes: did not turn on.
Tanvir Ahmed Howlader - Responder
Microsoft band guide works well - I managed to remove the battery easily - but where do I get a new battery from ?
Margo Bowes - Responder
TWO WORDS:
THANK YOU!
(A++++)
Somebody know where to buy battery replacement?
I Want Fix IT - Responder
The only place i found was ebay:
ftlay - Responder
Batteries can be found on ebay. I was surprised to see the band come back to life. I found the “pop” connector difficult to align properly. Almost lost patience with it. Got it on, reassembled and it powered up.
Dwight Gaut - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 17
Duração total: 12,833
