Ir para o conteúdo principal
Michael Kors Watch Link Band Replacement
O que você precisa
  1. Michael Kors Watch Link Band Replacement, Link Band: passo 1, imagem 1 %32
    • Place the watch on your wrist and determine whether links should be added or removed.
    • If watchband needs to be expanded, approximate the number of links required.
  2. Michael Kors Watch Link Band Replacement: passo 2, imagem 1 %32 Michael Kors Watch Link Band Replacement: passo 2, imagem 2 %32 Michael Kors Watch Link Band Replacement: passo 2, imagem 3 %32
    • Set the watch on the block holder.
    • Ensure the arrows located on the links are pointing downward.
  3. Michael Kors Watch Link Band Replacement: passo 3, imagem 1 %32
    • When removing damaged or extra links, hold one end of the pin pusher against the pin to be removed.
    • Strike the other end of the pin pusher with the metal side of the watch hammer until the pin slides out.
    • Two pins hold each link to the band, so two pins must be removed per link.
  4. Michael Kors Watch Link Band Replacement: passo 4, imagem 1 %32
    • Discard the broken links or save any extra links that you remove.
  5. Michael Kors Watch Link Band Replacement: passo 5, imagem 1 %32 Michael Kors Watch Link Band Replacement: passo 5, imagem 2 %32
    • To add links to the watchband, position the watch on the block holder with the arrows facing upward.
    • Insert pins into the holes that connect the new link to the rest of the watchband.
    • Use the soft side of the hammer to strike the pin down.
  6. Michael Kors Watch Link Band Replacement: passo 6, imagem 1 %32 Michael Kors Watch Link Band Replacement: passo 6, imagem 2 %32
    • Lastly, make sure that all the pins joining the links are secured in place.
Conclusão
7 outras pessoas executaram este guia.
9Comentários do guia
How do I replace a broken link when it's the very first link that connects the band to the actual watch?
Karen Perri - Responder
How can I puchace the first link on my Michael kors ceramic watch
melissa.costello31 -
I need first link to attach to micheal kors ceramic white watch
The lady when I bought my watch at the mall told me that Michael Kors will give you two free links I'm trying to figure out how I can go about getting that
Claudia Mead - Responder
Where can I get the white bands that cover the links on my my watch as a few have bits broken
Karenclemo@gmail.com - Responder
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 45
Últimos 30 dias: 200
Ao todo: 78,868
