Ir para o conteúdo principal
Mia Toro Luggage Wheel Replacement
O que você precisa
    1. Mia Toro Luggage Wheel Replacement, Mia Toro Luggage Wheel: passo 1, imagem 1 %32 Mia Toro Luggage Wheel Replacement, Mia Toro Luggage Wheel: passo 1, imagem 2 %32 Mia Toro Luggage Wheel Replacement, Mia Toro Luggage Wheel: passo 1, imagem 3 %32
      • Unzip the inner lining on the side of the suitcase where the broken wheel is located.
      • Lift the lining to the side and you will be able to see the screws holding the wheel in place.
      Pergunte ao FixBot
      Comentar
    2. Mia Toro Luggage Wheel Replacement: passo 2, imagem 1 %32
      • Use a Phillips #2 screwdriver to remove the four screws securing the damaged wheel.
      Pergunte ao FixBot
      Comentar
    3. Mia Toro Luggage Wheel Replacement: passo 3, imagem 1 %32
      • Pull the damaged wheel assembly straight out from the suitcase to remove it.
      • The wheel should come off very easily once the screws are removed.
      Pergunte ao FixBot
      Comentar
    4. Mia Toro Luggage Wheel Replacement: passo 4, imagem 1 %32 Mia Toro Luggage Wheel Replacement: passo 4, imagem 2 %32
      • Align the new wheel with the screw holes in the wheel housing.
      • Make sure it sits flush against the luggage.
      Pergunte ao FixBot
      Comentar
    5. Mia Toro Luggage Wheel Replacement: passo 5, imagem 1 %32
      • Insert the screws into the wheel assembly from the inside of the suitcase and use the Phillips #2 screwdriver to tighten them evenly.
      • Ensure the wheel is firmly attached but avoid overtightening, which could lead to stripping the screw holes.
      Pergunte ao FixBot
      Comentar
    6. Mia Toro Luggage Wheel Replacement: passo 6, imagem 1 %32
      • Spin the wheel and roll the luggage to ensure smooth movement.
      • If the wheel wobbles or feels loose, check and tighten the screws as needed.
      • Zip the inner lining back into place and your luggage is ready to use!
      Pergunte ao FixBot
      Comentar
Conclusão
Beatriz Amaral Soares
Membro desde: 01/13/25
133 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 33
Últimos 30 dias: 138
Ao todo: 1,744
