Ir para o conteúdo principal
MiTM Pressure Washers CA2703HDHB1 2017 Recoil Starter Replacement
O que você precisa
  1. MiTM Pressure Washers CA2703HDHB1 2017 Recoil Starter Replacement, Remove the recoil starter bolts: passo 1, imagem 1 %32
    • Before you begin, be sure that the engine is powered off and is cool to the touch.
    • Use a 10 mm socket to remove the three 24 mm long bolts.
  2. MiTM Pressure Washers CA2703HDHB1 2017 Recoil Starter Replacement, Remove the recoil starter assembly: passo 2, imagem 1 %32
    • Remove the recoil starter assembly.
  3. MiTM Pressure Washers CA2703HDHB1 2017 Recoil Starter Replacement: passo 3, imagem 1 %32 MiTM Pressure Washers CA2703HDHB1 2017 Recoil Starter Replacement: passo 3, imagem 2 %32
    • If you are replacing the assembly with a non-OEM part, you may also have to replace the starter cap.
    • Remove the 3/4" bolt with a deep socket.
    • This bolt can be very difficult to remove. Use the hook as a bracing point to keep the starter cap from rotating.
Conclusão
Uma outra pessoa concluiu este guia.
Arthur Shi
Membro desde: 01/03/18
252.675 Reputação
Autoria de 526 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.767 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 17
Duração total: 673
