Ir para o conteúdo principal
MiJia Bluetooth Thermometer (2 Battery) Replacement
O que você precisa
  1. MiJia Bluetooth Thermometer (2 Battery) Replacement, Open the back plate: passo 1, imagem 1 %32 MiJia Bluetooth Thermometer (2 Battery) Replacement, Open the back plate: passo 1, imagem 2 %32 MiJia Bluetooth Thermometer (2 Battery) Replacement, Open the back plate: passo 1, imagem 3 %32
    • Insert the flat side of your spudger or your finger nail into the crack located the back-bottom of the device.
    • While inserted, use gentle force to lift the bottom up, then, use a Opening pick or your finger to remove all the clips.
    • The bottom should detach.
  2. MiJia Bluetooth Thermometer (2 Battery) Replacement, Change Battery: passo 2, imagem 1 %32
    • You need a spare CR2032 battery.
    • Remove the old battery and attach new battery from top.
Conclusão
You might need to wait few minute before the temperature synced up.
6512345
Membro desde: 09/06/24
133 Reputação
Autoria de 1 guia
1Comentário do guia
Thanks bro, that was really helpful and presented in a simple and easy way!
Kira Great - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 21
Ao todo: 281
