Introdução
Follow this guide to replace the power cord of a Mi-T-M CM1400HDEC1 2017 electric pressure washer.
This guide requires you to work around a large capacitor. Don’t attempt to remove the insulated wires from the capacitor unless you have the tools necessary to discharge it.
O que você precisa
Remove the four 59.2 mm-long 4 mm hex socket bolts from the electrical box.
Carefully pull the electrical box away from the engine until you have enough space to work inside it, making sure not to strain the cables that are still connected inside.
Unplug the two power cord wires (one black, one white) from the rails on the back of the power switch.
Remove the two Phillips screws securing the power cord strain relief bracket.
Remove the three wire ends of the power cord from the electrical box.
Remove the anchor from the original cord by pulling on it with a strong, steady force. You may need to use pliers or other gripping tools.
Once the anchor is free, remove the rubber stopper from inside it with a pair of needle nose pliers.
Finally, slide the empty anchor onto the new power cord, followed by the stopper. Then slide the anchor up onto the stopper until it can no longer be easily moved.
Once the wires are stripped, place new 14-16 AWG insulated quick disconnects onto the bare wire ends and use a crimper to secure them.
