Ir para o conteúdo principal
MerchSource the Black Series Boat Racer Gaskets Replacement
O que você precisa
  1. MerchSource the Black Series Boat Racer Gaskets Replacement, Gaskets: passo 1, imagem 1 %32 MerchSource the Black Series Boat Racer Gaskets Replacement, Gaskets: passo 1, imagem 2 %32
    • Remove the screw on the top of the boat at the rear end using a Phillips #2 screwdriver.
    • Screw length is 16 mm.
  2. MerchSource the Black Series Boat Racer Gaskets Replacement: passo 2, imagem 1 %32 MerchSource the Black Series Boat Racer Gaskets Replacement: passo 2, imagem 2 %32 MerchSource the Black Series Boat Racer Gaskets Replacement: passo 2, imagem 3 %32
    • Remove the top of the boat by sliding it backwards and then pulling it off.
  3. MerchSource the Black Series Boat Racer Gaskets Replacement: passo 3, imagem 1 %32 MerchSource the Black Series Boat Racer Gaskets Replacement: passo 3, imagem 2 %32
    • Grab the rubber gasket with tweezers and pull it out of the slot.
  4. MerchSource the Black Series Boat Racer Gaskets Replacement: passo 4, imagem 1 %32 MerchSource the Black Series Boat Racer Gaskets Replacement: passo 4, imagem 2 %32 MerchSource the Black Series Boat Racer Gaskets Replacement: passo 4, imagem 3 %32
    • Gently remove the gasket and replace with a new one.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 245
