Ir para o conteúdo principal
MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement
O que você precisa
  1. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement, Battery Contacts in Remote Controller: passo 1, imagem 1 %32 MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement, Battery Contacts in Remote Controller: passo 1, imagem 2 %32
    • Turn the remote controller over to the back.
  2. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: passo 2, imagem 1 %32
    • Slide the battery cover off in the direction of the arrow on the cover.
  3. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: passo 3, imagem 1 %32 MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: passo 3, imagem 2 %32
    • Remove the batteries (2 AA).
  4. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: passo 4, imagem 1 %32
    • Using a Phillips #1 screwdriver, remove the four screws located in the four corners of the back of the remote controller.
    • Screw length is 6 mm.
  5. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: passo 5, imagem 1 %32 MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: passo 5, imagem 2 %32
    • Separate the two halves of the remote controller.
  6. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: passo 6, imagem 1 %32 MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: passo 6, imagem 2 %32
    • Lift the metal tab until it is straight and can move through the slot in the battery compartment.
  7. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: passo 7, imagem 1 %32 MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: passo 7, imagem 2 %32
    • Flip the remote controller to the external side and slide the metal connections in the battery compartment straight up.
    • Slide the new connections straight down into the slot in the battery compartment, flip to the internal side, and bend the metal tab until it's parallel with the battery compartment.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 208
