Ir para o conteúdo principal
Merch Source Projector Entertainment II Outer Lens Replacement
O que você precisa
  1. Merch Source Projector Entertainment II Outer Lens Replacement, Outer Casing: passo 1, imagem 1 %32 Merch Source Projector Entertainment II Outer Lens Replacement, Outer Casing: passo 1, imagem 2 %32
    • Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
  2. Merch Source Projector Entertainment II Outer Lens Replacement: passo 2, imagem 1 %32
    • Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
    • The bottom right panel screw does not come completely out the panel door.
  3. Merch Source Projector Entertainment II Outer Lens Replacement: passo 3, imagem 1 %32 Merch Source Projector Entertainment II Outer Lens Replacement: passo 3, imagem 2 %32
    • Using your hands, gently pry the top and bottom of the projector casing apart.
  4. Merch Source Projector Entertainment II Outer Lens Replacement, Ribbon Cable Detachment: passo 4, imagem 1 %32 Merch Source Projector Entertainment II Outer Lens Replacement, Ribbon Cable Detachment: passo 4, imagem 2 %32
    • Use the plastic opening tool to gently disengage the black clip housing from the ribbon cable.
    • Once the ribbon cable is disengaged gently pull the cable off the motherboard.
    • Once the housing is disengaged, the ribbon cable should slide out easily. Do not pull too hard on the ribbon cable as it is very fragile.
  5. Merch Source Projector Entertainment II Outer Lens Replacement, Motherboard Detachment: passo 5, imagem 1 %32 Merch Source Projector Entertainment II Outer Lens Replacement, Motherboard Detachment: passo 5, imagem 2 %32 Merch Source Projector Entertainment II Outer Lens Replacement, Motherboard Detachment: passo 5, imagem 3 %32
    • Unscrew the three 7 mm screws from the motherboard with the Phillips #0 screw driver.
    • Once loose, lift the motherboard off of the lens casing, and move it away from the workspace.
    • Be sure not to damage any of the wires atached to the motherboard.
  6. Merch Source Projector Entertainment II Outer Lens Replacement, Lens Casing Detachment: passo 6, imagem 1 %32 Merch Source Projector Entertainment II Outer Lens Replacement, Lens Casing Detachment: passo 6, imagem 2 %32 Merch Source Projector Entertainment II Outer Lens Replacement, Lens Casing Detachment: passo 6, imagem 3 %32
    • Unscrew the four 15mm Phillips screws using the Phillips #0 screw driver.
    • Unscrew the two 12mm Phillips screws using the Phillips #0 screw driver.
    • Gently remove the entire lens casing from its position.
  7. Merch Source Projector Entertainment II Outer Lens Replacement, Lens Casing Seperation: passo 7, imagem 1 %32 Merch Source Projector Entertainment II Outer Lens Replacement, Lens Casing Seperation: passo 7, imagem 2 %32 Merch Source Projector Entertainment II Outer Lens Replacement, Lens Casing Seperation: passo 7, imagem 3 %32
    • Using the plastic opening tool, slightly separate the casing holding the large lens in place.
    • Separate the casing completely from the inner lens using your hands.
    • This should release the outer lens and it's immediate casing.
    • As you separate the outer casing, the lens and digital display box may fall out of their encasement.
    • Although there are threads connecting the outer lens casing and the inner lens casing, do not be fooled. The outer lens casing cannot be disconnected by unscrewing it.
  8. Merch Source Projector Entertainment II Outer Lens Replacement, Outer Lens Casing Seperation: passo 8, imagem 1 %32 Merch Source Projector Entertainment II Outer Lens Replacement, Outer Lens Casing Seperation: passo 8, imagem 2 %32 Merch Source Projector Entertainment II Outer Lens Replacement, Outer Lens Casing Seperation: passo 8, imagem 3 %32
    • Unscrew the four 8mm Phillips screws at the base of the outer lens casing using the Phillips #0 screw driver.
    • Separate the white outer casing from the black outer casing.
  9. Merch Source Projector Entertainment II Outer Lens Replacement, Final Outer Lens Removal: passo 9, imagem 1 %32 Merch Source Projector Entertainment II Outer Lens Replacement, Final Outer Lens Removal: passo 9, imagem 2 %32
    • Using your finger, gently push the lens out of its white encasement.
    • The outer lens is now free and ready for replacement.
Conclusão
Stephanie
Membro desde: 01/08/15
282 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 18-3, Maness Winter 2015 Membro de Cal Poly, Team 18-3, Maness Winter 2015
CPSU-MANESS-W15S18G3
3 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 51
Ao todo: 3,490
