Introdução
The radiator hoses on your car are subject to a lot of abuse. Heat, expansion and contraction, corrosives, etc. attack them every time you drive and even when you're parked.The rubber hoses will eventually become brittle, and could begin leaking at their ends or may even crack and leak along their length.Be proactive and replace them today. All you need is a screwdriver!
O que você precisa
Begin by draining your radiator of coolant as [link de guia inválido]. You will not need to drain the block for this process.
Then go underneath the car and loosen the clamp on the lower radiator hose where it connects to the radiator.
Remove the hose in the same manner you did the upper hose.
Now replace both hoses, and secure with hose clamps. Replace the hose clamps with new ones if they were difficult to open due to corrosion or stripped screw heads.
Finish by filling the system with coolant and bleeding the system as [link de guia inválido]
4 outras pessoas executaram este guia.
