Introdução
The fuel sending unit works off resistance as a float moves up and down a fragile set of wires inside the float tube that makes up the body of the unit. If your fuel sending unit has damaged lines, a stuck float, etc. you will likely want to remove it to replace it with a good used part, a new part, or to attempt to clean it or repair it. This guide will help you remove the part so you can proceed.
O que você precisa
Before being able to proceed you will need to remove the first aid box. This guide does not cover this step, but basically, when you remove the first aid kit you will see several Phillips screws in the bottom of the box. Remove those and the first aid box lifts out.
Use your large socket (1 and 13/16") and a ratchet to unscrew the fuel sending unit.
Optionally, you can use a large adjustable wrench or channel locks though when using tools like this there is always the potential for damaging the top of the fuel sending unit. Having the correct size socket is always preferable.
You can now begin to pull the fuel sending unit out. Do it slowly.
Before removing it all the way, let the fuel in the unit drain out. You should hear it slowly draining as you pull it up. The more fuel that is in your tank the longer it will take to drain the unit.
Once it's drained you can remove it all the way to service it or to proceed at installing your replacement part.
15 outras pessoas executaram este guia.
6 comentários
while soundproofing my 84 300d i removed the box and covered the hole with sheet metal. thanks to you i will be removing the metal and trying to remember if i kept the box. the lid was already missing. good stuff thanks p.s. i think i will weld a 1/2" drive socket onto my 1 13/16" socket. i have extras
11.2.16
For Diesel cars, the sender often has fungus lurking inside it and it's easy to take apart and clean if *VERY*DELICATE* .
Use some small delicate pliers to pinch the soft plastic surround protecting the special nut and unscrew it then it all comes apart easily .
Work over a clean light colored cloth and use electro - contact cleaner or aerosol starting fluid to clean the funky black fungus ~ you need to get every bit of it out, use a soft toothbrush on the bottom part .
Test easily by tipping the sender up and down with the plug attached and the key on .
-Nate
My car has been sitting for 9 years and they're sending unit isn't working or the gas gauge does not work. What should I check for first.
Craig -
God pm sir.how much is fuel sending unit for 123/300d
Sable Quisiera donde lleva el tiempo de temperatura mercedes ben 280e 1981
dose any one know where you can get the silver nichrome 42 gauge and copper wire to repair the fuel tank sender in a1982 mercedes benz w123123 240d
