Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
As is the case with any rubber parts on your approximately 30 year old car the fuel filler neck seal on your W123 may not be functioning as it should be. If you use alternative fuels this can be exacerbated by the fuel's reaction when it contacts the rubber. Change it today before you get water, fuel, or dirt in to your trunk through this opening.
O que você precisa
When inspecting your fuel filler neck seal look for dryness, brittleness, or like on this particular diesel W123 obvious damage. This was caused by drips of B99 biodiesel on the already aged rubber seal.
Once finished, consider covering the rubber seal in a light coating of silicone grease to help preserve it.
10 outras pessoas executaram este guia.
