Ir para o conteúdo principal
Mercedes W123 Fuel Cap and Oil Cap Seal Replacement
O que você precisa
  1. Mercedes W123 Fuel Cap and Oil Cap Seal Replacement, Fuel Cap and Oil Cap Seal: passo 1, imagem 1 %32 Mercedes W123 Fuel Cap and Oil Cap Seal Replacement, Fuel Cap and Oil Cap Seal: passo 1, imagem 2 %32 Mercedes W123 Fuel Cap and Oil Cap Seal Replacement, Fuel Cap and Oil Cap Seal: passo 1, imagem 3 %32
    • As noted in the introduction there are two styles of oil caps. One of the cars used in the creation of this guide has the old style metal oil cap. Therefore, two fuel cap seals will be used; one for the fuel cap, and one for the oil cap. These are pictured.
    • The other car used has the new style plastic cap. In this case, you'll need one fuel cap seal, and one plastic oil cap seal.
  2. Mercedes W123 Fuel Cap and Oil Cap Seal Replacement: passo 2, imagem 1 %32
    • Remove the first cap that is leaking. In this picture, it is the fuel cap.
    • Using a flat blade screwdriver, gently lift the old seal out. In the case of the old black fuel seal pictured, it was very brittle; it had become about as flexible as plastic instead of rubber.
    • Install the new seal, stretching it around the two metal tabs that extend out of the center of the cap.
    • Repeat with the next cap, in this case the metal oil cap. That seal was still fairly soft, and was not leaking on this car, but was replaced as preventative maintenance.
  3. Mercedes W123 Fuel Cap and Oil Cap Seal Replacement: passo 3, imagem 1 %32 Mercedes W123 Fuel Cap and Oil Cap Seal Replacement: passo 3, imagem 2 %32
    • Alternatively, replace the seal on your new style plastic oil filler cap.
    • This seal is thinner, and a bit harder to remove. Gently pull it out with needle nose pliers being careful not to damage the cap.
    • Just like the seal on the fuel cap previously pictured, this seal is somewhat hardened and has a permanent groove in it. Replacing it with a new seal will likely stop the oil staining no the valve cover around it.
Conclusão
Once the seals are replaced simply re-install the caps. After driving, check for any leaks and try to re-seat the seals if there are any.
8 outras pessoas executaram este guia.
Nicolas Siemsen
Membro desde: 12/06/13
39.010 Reputação
Autoria de 79 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.521 guias
2 comentários
My car the flow of oil by oil cap where the problem I will thanks if you guide me how to do
basher464 - Responder
I replaced my fuel filler cap sal with the blue nitrile? seal and it does seal. But!!! when t was time to refuel (approx 2 wks) the cap was extremely hard to break loose. Much too hard for my wife to open. So I applied some silicone grease. That helped but only one cycle worth. Seems diesel fuel dissolves the grease. So I'm back to replacing the $18 blue gasket with a regular gasket.
carste10 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 36
Duração total: 10,295
