Ir para o conteúdo principal
Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement
O que você precisa
  1. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement, Tail/Reverse/Rear Turn Signal Bulb: passo 1, imagem 1 %32
    • The access panel for all of these lights is on the inside of the trunk. There's one on each side. This guide will cover one side; simply repeat on the other to complete the job.
  2. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: passo 2, imagem 1 %32
    • The panel is secured with two thumb screws. Remove these.
  3. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: passo 3, imagem 1 %32
    • Pull the panel out and away from the back of the car, being careful not to force the bulbs out of the holes.
  4. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: passo 4, imagem 1 %32
    • There are five bulbs in each tail light housing. They are as follows:
    • Brake light
    • Reverse light
    • Tail light
    • Turn signal
    • Side marker
  5. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: passo 5, imagem 1 %32
    • To remove any of the bulbs simply turn them counter clockwise approximately a half turn and then pull them out of their socket.
  6. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: passo 6, imagem 1 %32 Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: passo 6, imagem 2 %32 Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: passo 6, imagem 3 %32
    • Three of the bulbs are #1156
    • One is a #96
    • One is a small 4W blub
  7. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: passo 7, imagem 1 %32
    • Before installing the new bulb consider cleaning the socket with a soft metal wire brush such as the brass brush shown to help remove any corrosion.
    • Then install the new bulb, reassemble the device, and finally, be sure to test that all of your rear lights are working before going for a drive.
Conclusão
10 outras pessoas executaram este guia.
Nicolas Siemsen
Membro desde: 12/06/13
39.284 Reputação
Autoria de 79 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 321
Autoria de 1.525 guias
2 comentários
Very informative, descriptive and point on analysis.
George T Peeke - Responder
Und wie wird dies beim Kombi gemacht?
srossius - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 17
Últimos 30 dias: 71
Duração total: 12,505
