Ir para o conteúdo principal
Mercedes W114/W115 Cluster Clock replacement and troubleshooting
O que você precisa
  1. Mercedes W114/W115 Cluster Clock replacement and troubleshooting, Cluster Clock: passo 1, imagem 1 %32 Mercedes W114/W115 Cluster Clock replacement and troubleshooting, Cluster Clock: passo 1, imagem 2 %32
    • Locate the area that houses the clock. Unscrew the two barrels and place it aside.
    • Carefully pull out the clock without damaging any other parts.
  2. Mercedes W114/W115 Cluster Clock replacement and troubleshooting: passo 2, imagem 1 %32 Mercedes W114/W115 Cluster Clock replacement and troubleshooting: passo 2, imagem 2 %32 Mercedes W114/W115 Cluster Clock replacement and troubleshooting: passo 2, imagem 3 %32
    • Connect the screw (located behind the clock) to the negative supply of the battery, and then the small pin to the positive supply.
  3. Mercedes W114/W115 Cluster Clock replacement and troubleshooting: passo 3, imagem 1 %32 Mercedes W114/W115 Cluster Clock replacement and troubleshooting: passo 3, imagem 2 %32 Mercedes W114/W115 Cluster Clock replacement and troubleshooting: passo 3, imagem 3 %32
    • To check the clock, set the time to something you can remember and set it aside.
  4. Mercedes W114/W115 Cluster Clock replacement and troubleshooting: passo 4, imagem 1 %32 Mercedes W114/W115 Cluster Clock replacement and troubleshooting: passo 4, imagem 2 %32 Mercedes W114/W115 Cluster Clock replacement and troubleshooting: passo 4, imagem 3 %32
    • To check the power supply of the clock, locate the electrical connector and find the pin on it which supplies the power (12v) to the clock.
    • Take a small bulb and socket and bridge a wire from the 12v pin supplied from the electrical connector, to one of the two wires on the bulb and socket.
    • Next find a ground supply nearby ( the best place would be the key hole) and bridge another wire from it to the second available wire on the bulb and socket.
    • If the bulb lights up, it means your clock has power.
  5. Mercedes W114/W115 Cluster Clock replacement and troubleshooting: passo 5, imagem 1 %32 Mercedes W114/W115 Cluster Clock replacement and troubleshooting: passo 5, imagem 2 %32
    • If the bulb lights up, the power supply to the clock is good.
  6. Mercedes W114/W115 Cluster Clock replacement and troubleshooting: passo 6, imagem 1 %32
    • Before putting the clock in, clean the holder with a sand paper or a flat headed screw driver.
    • Start reassembling the dashboard by following the guide in reverse order.
    • While reassembling, be careful not to damage the wire harness , oil pressure meter hose, and temperature meter cable.
Conclusão
4 outras pessoas executaram este guia.
Chaga Edirisinghe
Membro desde: 02/20/14
301 Reputação
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 26
Ao todo: 6,684
