Ir para o conteúdo principal
Merangue Steel 3-Hole Punch Head Replacement
O que você precisa
  1. Merangue Steel 3-Hole Punch Head Replacement, Punch Head: passo 1, imagem 1 %32 Merangue Steel 3-Hole Punch Head Replacement, Punch Head: passo 1, imagem 2 %32 Merangue Steel 3-Hole Punch Head Replacement, Punch Head: passo 1, imagem 3 %32
    • Tilt the hole puncher on its back.
    • Use a flathead screwdriver to remove the three screws.
  2. Merangue Steel 3-Hole Punch Head Replacement: passo 2, imagem 1 %32 Merangue Steel 3-Hole Punch Head Replacement: passo 2, imagem 2 %32 Merangue Steel 3-Hole Punch Head Replacement: passo 2, imagem 3 %32
    • Use your finger to slide the punch head out towards the opening (right in this case).
    • Remove the punch head from the opening and set it aside.
    • Repeat this step with the other punch heads.
  3. Merangue Steel 3-Hole Punch Head Replacement: passo 3, imagem 1 %32 Merangue Steel 3-Hole Punch Head Replacement: passo 3, imagem 2 %32 Merangue Steel 3-Hole Punch Head Replacement: passo 3, imagem 3 %32
    • Take your replacement hole punch and push it into the opening.
    • Slide the hole punch to your desired alignment in my case, left).
    • Make sure the hole punch is properly aligned (the hole at the back should point directly at the ceiling).
  4. Merangue Steel 3-Hole Punch Head Replacement: passo 4, imagem 1 %32 Merangue Steel 3-Hole Punch Head Replacement: passo 4, imagem 2 %32 Merangue Steel 3-Hole Punch Head Replacement: passo 4, imagem 3 %32
    • Use your fingers to screw one of the screws into the hole on the back of the punch head.
    • The screw can be a bit difficult to align so be patient and don't rush.
    • Take your flat head screwdriver and tighten the screw.
    • Repeat these steps for the other punch heads.
Linha de Chegada
Noah Dela Calzada
Membro desde: 01/16/24
109 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 17
Duração total: 149
