Ir para o conteúdo principal
Peças
Nenhum componente especificado.
  1. Locate the 'OPEN' tab on the battery compartment. Pull the tab upwards and remove the cover using your finger. Remove the batteries.
    • Locate the 'OPEN' tab on the battery compartment.
    • Pull the tab upwards and remove the cover using your finger.
    • Remove the batteries.
  2. Locate the screws on the bottom of the device that hold the upper and lower halves together. Remove the (5) 19mm screws. Grasp the top and bottom and gently pull apart.
    • Locate the screws on the bottom of the device that hold the upper and lower halves together.
    • Remove the (5) 19mm screws.
    • Grasp the top and bottom and gently pull apart.
Conclusão
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 18
