Ir para o conteúdo principal
Meepo Mini 5 Truck Bushing Replacement
O que você precisa
  1. Meepo Mini 5 Truck Bushing Replacement, Truck Bushing: passo 1, imagem 1 %32 Meepo Mini 5 Truck Bushing Replacement, Truck Bushing: passo 1, imagem 2 %32
    • Rotate the half-inch wrench counter-clockwise to loosen the bushing bolt.
  2. Meepo Mini 5 Truck Bushing Replacement: passo 2, imagem 1 %32 Meepo Mini 5 Truck Bushing Replacement: passo 2, imagem 2 %32
    • Take out the truck bushing (orange part).
  3. Meepo Mini 5 Truck Bushing Replacement: passo 3, imagem 1 %32
    • Take the wheels out of the screw by pulling it toward you.
  4. Meepo Mini 5 Truck Bushing Replacement: passo 4, imagem 1 %32
    • Remove the washer from the top of the bushing.
  5. Meepo Mini 5 Truck Bushing Replacement: passo 5, imagem 1 %32
    • Take out the bottom bushing (orange part).
  6. Meepo Mini 5 Truck Bushing Replacement: passo 6, imagem 1 %32
    • Take off the metal cap from the bushing.
  7. Meepo Mini 5 Truck Bushing Replacement: passo 7, imagem 1 %32
    • Replace with the new bushing to the cap.
  8. Meepo Mini 5 Truck Bushing Replacement: passo 8, imagem 1 %32
    • Press the bushing back.
  9. Meepo Mini 5 Truck Bushing Replacement: passo 9, imagem 1 %32 Meepo Mini 5 Truck Bushing Replacement: passo 9, imagem 2 %32
    • Press the hanger back (wheels)
    • Press the wire and point the semicircular ridge to the hole at the same time as the space is narrow.
  10. Meepo Mini 5 Truck Bushing Replacement: passo 10, imagem 1 %32
    • Press the upper bushing and the cap back on.
  11. Meepo Mini 5 Truck Bushing Replacement: passo 11, imagem 1 %32
    • Press the pin back on.
  12. Meepo Mini 5 Truck Bushing Replacement: passo 12, imagem 1 %32
    • Rotate the 1/2 inch wrench clockwise to tighten the pin.
Conclusão
Richard
Membro desde: 04/25/24
205 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 3-1, Whithaus Spring 2024 Membro de UC Davis, Team 3-1, Whithaus Spring 2024
UCD-WHITHAUS-S24S3G1
Membros da 3
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 117
