Introdução
This guide will provide instructions for removing the speaker and mic in a Maze Speed phone. You will need a plastic opening tool, screwdriver, tweezers and soldering equipment. You should know how to solder to avoid damaging other components in the phone.
O que você precisa
With the phone face down, remove the back cover with the plastic opening tool. For easiest access, insert the plastic opening tool in the bottom left corner.
Quase terminado!
Conclusão
