Ir para o conteúdo principal
Maze Speed SSB-508 Battery Port Replacement
O que você precisa
  1. Maze Speed SSB-508 Battery Port Replacement, Motherboard: passo 1, imagem 1 %32 Maze Speed SSB-508 Battery Port Replacement, Motherboard: passo 1, imagem 2 %32 Maze Speed SSB-508 Battery Port Replacement, Motherboard: passo 1, imagem 3 %32
    • Remove the back cover by inserting the plastic opening tool at the bottom left corner of the device.
    Pergunte ao FixBot
  2. Maze Speed SSB-508 Battery Port Replacement: passo 2, imagem 1 %32 Maze Speed SSB-508 Battery Port Replacement: passo 2, imagem 2 %32
    • Remove fifteen 2mm Phillips #00 screws.
    Pergunte ao FixBot
  3. Maze Speed SSB-508 Battery Port Replacement: passo 3, imagem 1 %32 Maze Speed SSB-508 Battery Port Replacement: passo 3, imagem 2 %32 Maze Speed SSB-508 Battery Port Replacement: passo 3, imagem 3 %32
    • Lift the plastic opening tool up at the bottom left corner to create the gap.
    • Repeat this through all corners to remove the internal casing.
    Pergunte ao FixBot
  4. Maze Speed SSB-508 Battery Port Replacement: passo 4, imagem 1 %32 Maze Speed SSB-508 Battery Port Replacement: passo 4, imagem 2 %32 Maze Speed SSB-508 Battery Port Replacement: passo 4, imagem 3 %32
    • Unscrew the 2mm screw at the bottom right of the motherboard.
    • Remove the internal antenna casing from the motherboard.
    Pergunte ao FixBot
  5. Maze Speed SSB-508 Battery Port Replacement: passo 5, imagem 1 %32 Maze Speed SSB-508 Battery Port Replacement: passo 5, imagem 2 %32
    • Unplug the speaker at the top of the motherboard.
    Pergunte ao FixBot
  6. Maze Speed SSB-508 Battery Port Replacement: passo 6, imagem 1 %32 Maze Speed SSB-508 Battery Port Replacement: passo 6, imagem 2 %32
    • Desolder the gold ribbon that is connected to the motherboard at the bottom left corner.
    Pergunte ao FixBot
  7. Maze Speed SSB-508 Battery Port Replacement: passo 7, imagem 1 %32 Maze Speed SSB-508 Battery Port Replacement: passo 7, imagem 2 %32 Maze Speed SSB-508 Battery Port Replacement: passo 7, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to remove cable from the ZIF connectors located at the bottom left of the motherboard.
    • Use the tweezers to remove the second cable from ZIF connector located to the right of the speaker that you unplugged in step five.
    • ZIF connector stands for Zero Insertion Force. Flip the small locking tap before removing the cable.
    Pergunte ao FixBot
  8. Maze Speed SSB-508 Battery Port Replacement: passo 8, imagem 1 %32 Maze Speed SSB-508 Battery Port Replacement: passo 8, imagem 2 %32
    • At this point, the motherboard should be able to be lifted up from the bottom.
    • Use the tweezers to dislodge the speaker.
    • After the speaker is dislodged, flip the motherboard up so that you can see the cable.
    • Using a soldering tool, desolder the cable from the back of the motherboard.
    Pergunte ao FixBot
  9. Maze Speed SSB-508 Battery Port Replacement: passo 9, imagem 1 %32
    • Remove the motherboard from the back.
    Pergunte ao FixBot
  10. Maze Speed SSB-508 Battery Port Replacement, Battery Port: passo 10, imagem 1 %32 Maze Speed SSB-508 Battery Port Replacement, Battery Port: passo 10, imagem 2 %32 Maze Speed SSB-508 Battery Port Replacement, Battery Port: passo 10, imagem 3 %32
    • Flip the motherboard upside down and you will see the battery port connected to the motherboard with 5 different soldered places.
    • Use the pliers to hold the motherboard and desolder the 5 places which are connected to the motherboard.
    Pergunte ao FixBot
  11. Maze Speed SSB-508 Battery Port Replacement: passo 11, imagem 1 %32
    • Use the tweezers to pull out the battery port.
    • Then, replace it with the new battery port.
    Pergunte ao FixBot
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 48
Ao todo: 1,746
