Ir para o conteúdo principal
Maytag MVWX655DW1 Washer Basket Hub Replacement
O que você precisa
  1. Maytag MVWX655DW1 Washer Basket Hub Replacement, Washer Basket Hub: passo 1, imagem 1 %32
    • Use a 1/4-in Flathead screwdriver to remove the three 5mm screws behind the washing machine.
  2. Maytag MVWX655DW1 Washer Basket Hub Replacement: passo 2, imagem 1 %32 Maytag MVWX655DW1 Washer Basket Hub Replacement: passo 2, imagem 2 %32 Maytag MVWX655DW1 Washer Basket Hub Replacement: passo 2, imagem 3 %32
    • Tape the lid down so it does not open when removing.
    • Pull the lid forward with your thumbs while pushing against the washer with your fingers.
    • Lift the lid up and place on the slots located where you removed the screws from the back.
  3. Maytag MVWX655DW1 Washer Basket Hub Replacement: passo 3, imagem 1 %32 Maytag MVWX655DW1 Washer Basket Hub Replacement: passo 3, imagem 2 %32 Maytag MVWX655DW1 Washer Basket Hub Replacement: passo 3, imagem 3 %32
    • Remove the cap from the agitator with your flat head screwdriver. It should pop right off.
    • Using your 7/16 socket, unscrew the bolt attaching the agitator to the motor shaft.
  4. Maytag MVWX655DW1 Washer Basket Hub Replacement: passo 4, imagem 1 %32 Maytag MVWX655DW1 Washer Basket Hub Replacement: passo 4, imagem 2 %32 Maytag MVWX655DW1 Washer Basket Hub Replacement: passo 4, imagem 3 %32
    • Lift up on the agitator and it should slide off the motor shaft exposing the washer hub underneath.
    • If it is stuck, put bolt back in halfway. Tap the bolt with a hammer while pulling up on the agitator to jog it loose.
  5. Maytag MVWX655DW1 Washer Basket Hub Replacement: passo 5, imagem 1 %32 Maytag MVWX655DW1 Washer Basket Hub Replacement: passo 5, imagem 2 %32 Maytag MVWX655DW1 Washer Basket Hub Replacement: passo 5, imagem 3 %32
    • Use your Phillips #3 screwdriver to pull the retaining slip out.
    • Unscrew the six screws with the same Phillips #3 screwdriver to remove the hub.
  6. Maytag MVWX655DW1 Washer Basket Hub Replacement: passo 6, imagem 1 %32 Maytag MVWX655DW1 Washer Basket Hub Replacement: passo 6, imagem 2 %32
    • Take the new hub and slide it over the motor shaft.
    • Align the holes by only slightly screwing in each screw and turning the hub until all holes are aligned and screws are in.
    • Tighten all screws and then put new retaining clip into hub.
Conclusão
Kyle
Membro desde: 02/18/21
133 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 40
Últimos 30 dias: 247
Duração total: 8,181
